Radio / speaker upgrade questions
I've done a lot of searches and can't find the info I'm looking for. I'm going to upgrade the sound system and thought I'd ask here before going any further. Any help is much appreciated.
I have the non-bose system;
1) I have read that there are some non-bose systems that have an amp and some that do not. Is this correct? How can I tell which system I have?
2) Assuming no amp, can I simply install a new head unit then use the existing speaker wiring to upgrade the factory speakers?
Thanks.
Thanks.
http://www.6speedonline.com/forums/9...3-22-15-a.html
What I followed to replace the speakers in my 2007. Should be same/similar for non Bose though.
If you're looking to put in a nice system with HU, amp, component speakers, sub, etc., I can help you. Otherwise the budget audio thread above is decent.
Thanks. I'll check both. Is the amp well-hidden or in plain view?
I had been thinking to upgrade the audio system in my 997, but after hours of research and consultation I finally realized that 911 generation is not the right car for audio upgrades: Cabin is too small and too noisy from tires and engine, doors are not well insulated for audio, etc. Save time and money and keep the OEM equipment, and enjoy the NA engine. But if you are ready to spend some money anyway...go with a good exhaust system.
Peace
Bruce in Philly
