View Poll Results: Poll: Have you had bore scoring on your 997.1 or 997.2 engine?
Yes, 997.1 (05-08 MY)
143
14.43%
Yes, 997.2 (09-12 MY)
18
1.82%
No, 997.1 (05-08 MY)
527
53.18%
No, 997.2 (09-12 MY)
303
30.58%
Voters: 991. You may not vote on this poll
Poll: Scored cylinder failure for your 997, Y or N? tell us (yr, 997.1 or 997.2)
#286
Purchased in 2009 with 17k on the odometer. Drove in Switzerland, and was in periods used for daily commute, which was 30 km each way, otherwise vacation drives of 2000-3000 km over a week or so.
In 2017 at 89k a big, white smoke cloud from the lefthand side exhaust appearsduring a drive on the autobahn at 130 km/t.. Porsche Center Kiel immediately suspects scored cylinder, quotes repair at Eur 28K. Take it to a reputable Danish indy Porsche specialist (I had relocated), who inspects in it and finds no scoring, changes the oil separator (Eur 3.5K). I drive 800 km, ticking noise appears and I take it to the indy again. Scored cylinder 6. Complete overhaul, new cylinders, IMS at Eur 12K incl discount. Drives 1000 km (600km, 200 and a few short trips), keeps it under 3'500 rpm, soot from the righthand side. Turns out there is an issue with the cylinder ring in cylinder 3. Fixed under repair warranty at indy. Drives 200 km (a few short trips). Still very sooty from the lefthand exhaust, and noticeable light smoke when driving off from traffic lights.
Oh, and the battery went dead after 4-5 days unused until Porsche Lausanne finally gave up a disabled the phone module.
Not too happy with Porsche right now. These are the issues that Germanpohiles point their finger at on Italian cars; my Maserati 3200 had zero issues. - I know, anecdotal evidence... My 1st gen Cayenne had perpetual issue with the electronic and front lights.
#287
It is a Carrera S 3.8. Gen I.
UPDATE: It is back again at the workshop. Same problem with cylinder 3. So, one oil separator change, one engine rebuild and two piston changes in 2000 km...
...AND, btw, the large water pipe wasn't properly attached after the first cylinder change, so I dropped all water on the highway after 200 km. - Weird thing is the specialist I use is very well regarded in my area.
#288
Hi, it is a Carrera S 3.8, Gen I. Loved the car - despite the battery issues and Navi being a bit erratic - until the scoring and subsequent cylinder 3 issues.
#292
3rd Gear
Bore scoring / engine rebuild discovered after purchase
Please include details of your car and engine if it failed (997.1 or 997.2) and when. I purchased my 2006 C2S in 2019 from a dealer in Virgnia. One previous owner in Baltimore. I noticed white smoke and high oil consumption and was able to contact the PO once I received the title. He told me he had the engine rebuilt in 2016 and gave me the name of the mechanic. I then spoke with the mechanic and he sent me the complete service history, including the $30k for the rebuild. Sent to L&N for boring it out to 4L and new coatings. All new internals. The PO then mostly had the car sit for three years (2k miles). I had my mechanic do a leak down and everything checked out, save the oil consumption of about a quart every 200 miles. I then used liquimoly (both oil and gas treatment), along with a couple of quarts of Marvel Mystery Oil and a triple treatment of Seafoam. Drove it hard. I mean hard. Took it on the 5 between San Diego and OC right after the lockdown and averaged 125 with plenty of changes in RPM. Changed the oil after 2k on the change in January of this year and am now burning a quart every 500. White smoke only once since the latest change. Will continue to change every 2k with LiquiMoly oil and gas treatments.
I do not know what caused the original failure at 33k miles. My guess is lack of driving and too many long periods of inactivity. She's a bit of a rescue in that I had to replace the headlamps, tires, windshield, AOS, alternator, plugs, bonnet paint, paint restoration, ceramic sealant, window trim, etc. Runs too good to believe. Black/Black, PASM, PCCB, PSE, 16 way full leather, factory short throw, and of course lobster fork 19's. Just turned 38k miles on the chassis with almost 5k on the motor. This is my 5th 911 and is by far my favorite.
Lucky the PO took care of the rebuild needless to say. He sold it to CarMax as it kept throwing the CEL. Turned out to be the valve lift hydraulic solenoids. The PO was 500 away from having a sound car.
#293
More than likely, bore scoring is what took the original engine out. There is a serial number on the block that we can use to trace who we did the block for and when, if you did want to know. We likely have photos of the block when it came in.
The biggest issues we see is that shops focus on the internals and the longblock itself and then skip changing injectors, MAF, primary o2 sensors, etc. - all of which affect fuel trims and can cause damage to the new engine, as new engines are extremely susceptible to fuel washdown. The other big mistake is shops either don't break the engine in right or switch to synthetic too soon. Both happen often enough that we had to come up with what we call a "corrective break-in procedure" to try to undo the damage caused. It can take thousands of miles to get the rings to seal up and get oil consumption back into what I would consider an acceptable range without having to pull the engine apart to de-glaze the bores and re-ring it.
#294
3rd Gear
If you have paperwork for what was done for the install of the new engine before you took ownership, I'd recommend looking at fuel trims. If they are off by more than 5%, that's likely not helping the oil consumption issue. I would also smoke test the engine to look for vacuum leaks as small ones can affect fuel trims but not cause a CEL.
#295
Thanks Charles - where on the engine block can I find the serial number? I can provide you the VIN here - WP0AB29906S740897. I already have been provided (by you) the corrective break-in procedures.
#297
Update
T4S - Please keep us posted and if you happen to get photos of the cylinder(s) it would be appreciated. Curious if this is the M9X style scoring (one side of piston, skirt center, coating flaky) or the 9A1 seizing Baz has described (both sides of piston, toward edge of skirt rather than center). On another thread Baz said he's seen five of these cases, all early 9A1 MY engines, all occurred in cold weather. Jake's video with Bronz's engine showed the same "both sides" pattern.
I am experiencing abnormal smokey starts and idle isn't as steady as you'd expect. About 850 miles driven - pulls smooth and runs better than scored.
MaksymKramarenko (06-10-2020)
#298
Here are some photos, sorry for delay all. Had cylinder 1 scoring and replacement engine done. I opted for new injectors but I'm reading above the need to change the o2 sensor - and what is MAP?
The shop putting the engine in should have also done a vehicle handover before first start to wipe out all the learned adaptations prior to the failure.
rtl5009 (07-16-2020)
#299
No failure. 997.1 2006
No failure.
997.1 c4s 2006
Ukraine, so +30C summer -30C winter (not the last one), moderate humidity.
65k km
no winter rides.
997.1 c4s 2006
65k km
no winter rides.
Last edited by MaksymKramarenko; 06-10-2020 at 04:02 PM. Reason: add info about my region
