DIY and Review - Function First Transmission Mount Insert for 997.2
1 Attachment(s)
My 997.2 PDK has just over 70k miles. I had written previously about how the original PDK Software gave really great, fast and hard (in a good aggressive way) shifts when in Sports Plus mode.
I had wondered whether this could be good for the gearbox, and had also noted that a PDK software update that was done on my car early last year definitely took away the harshness of the shifts in Sport Plus mode (although the speed of shifting was still excellent). There doesn’t seem to be any official data on why Porsche changed the shifting profile so much. It could have been because some customers didn’t like it, or for the purposes of longevity, or both…who knows) Nevertheless, the hard shifts would likely have some negative impact over time, at the very least on the transmission mounts. I coincidentally came across the following Function First Thread on Rennlist, and was intrigued by the idea. https://rennlist.com/forums/997-foru...-accuracy.html After spending way too much time reading all the reviews and feedback, I decided to order the SOFT inserts as it seemed like the safest bet to get the added support without introducing significant NVH (Noise Vibration Harshness) and potentially get improved shifting behavior at the same time. https://cimg9.ibsrv.net/gimg/rennlis...f8443a73d4.jpg https://cimg4.ibsrv.net/gimg/rennlis...466fb2ebb0.png https://cimg5.ibsrv.net/gimg/rennlis...118982f84a.png In summary, for my needs it was a great choice. The inserts fill the voids in the OEM bushing, to provide additional support and rigidity. Interestingly in the past many owners, particularly of older 911 models would fill these cavities with urethane based adhesives and other such products to restore rigidity to worn out bushings. The benefit of the FF mount is that there are several grades of stiffness and it is completely reversible or changeable if you decide to go for a different setup. Upon inspection, my OEM mount was still in very good condition, but I like the fact that this inexpensive and very simple DIY, provides more ridgidity and could prolong the life of the OEM bushing (and at the same time result in improved shifting performance). The DIY (attached) from the FF website is very helpful but there are 2 really important differences for the 997.2 PDK that need to be noted. - There is only a single Torx Bolt through the mount (not 2) - This bolt has a Torque spec of 63ft libs - You will need 20mm and 24mm Torx sockets for this https://cimg1.ibsrv.net/gimg/rennlis...928853cbdc.jpg The other bolts connecting the upper and lower mounts to the chassis have a torque spec of 48 ft lbs (this doesn’t include the actual mounting of the 2 studs which just need to be fully seated (7mm head). You will also see that the 997.2 has the “STOP” PART #3 shown below. these are not reused. https://cimg0.ibsrv.net/gimg/rennlis...36287786b5.png https://cimg5.ibsrv.net/gimg/rennlis...91b30f6d8a.jpg https://cimg6.ibsrv.net/gimg/rennlis...34d8ae0ece.jpg I personally would not want to do this DIY without a lift but it certainly could be done. The instructions referenced above are very good and describe the procedure perfectly so I won’t repeat all that. It should be noted that the transmission needs to be lifted only a few mm in order to pull the main mounting bolt out. One thing I did which was not necessary was remove the crossmember you will see in the last picture below. This does not need to come off. I also some PERL water based silicon solution to ease the installation of the insert, and used a rubber mallet to gently tap them into place to make them fully flush. Only one side was a little stubborn and needed some persuasion to fully seat. Transmission supported and main bolt removed: https://cimg6.ibsrv.net/gimg/rennlis...eae491f495.jpg OEM Stop removed https://cimg7.ibsrv.net/gimg/rennlis...fbe1fecf20.jpg Inserts installed https://cimg8.ibsrv.net/gimg/rennlis...0decf4d990.jpg https://cimg9.ibsrv.net/gimg/rennlis...ab43e57eb1.jpg https://cimg0.ibsrv.net/gimg/rennlis...498d0ccf89.jpg https://cimg1.ibsrv.net/gimg/rennlis...ae65c8a7e5.jpg Crossmember replaced https://cimg2.ibsrv.net/gimg/rennlis...608519477e.jpg After putting some decent miles on the car, my findings are as follows. Note I have the M&M Street Sport Exhaust so my car is considerably louder than stock. NVH - during cold starts no noticeable change at all due to the higher revs - during warm starts and if idling in Park or Neutral (just did this to experiment) there is some minor noise which is more noticeable if on an incline - it is difficult to describe but it is not obvious and cannot be heard at all from outside of the car. - Fortunately when stationary and in gear (e.g. when stopped at traffic light) there is no noise at all - The above is of no concern to me and I suspect this sound might diminish somewhat after I have a bit more time and miles on the part. Even if it doesn’t, the gains are worth the minor compromise. - when driving I would say there is a slight change in sound in the car. there seems to be a little more ‘whine’ (i.e. in addition to the intake sound, and a little more mechanical). It’s subtle, but it is a really good sound in my opinion. - my car is a pure weekend fun car with an "aggressive street" setup so I am even considering trying the next level up in stiffness just for comparison as the NVH is less of a concern for how I use the vehicle. Shifting - as mentioned earlier there was nothing wrong with the shift performance or the OEM mount to begin with - the only thing I did not like was downshifting from 2nd to 1st in Sport PLUS mode at low speeds (i.e. when coming to a stop), where there would often be a bit of a ‘clunk’ sound and some jerkiness. - this clunking seems to have been reduced/improved quite a bit - regarding all other shifts; whilst I am being overly cautious about being influenced by any potential placebo effect, I still think the shifting in Sports Plus is better. Still very fast but somehow more seamless and direct. - going to keep driving and will provide an update over the coming months Overall this is one of the easiest DIY’s you can do for both the preventative and performance benefit you get. I took it slow as I was being extra cautious with everything, having not worked on this part of my car before, and it took about 1.5 hours. I could probably do it again in about 45min’s now that I’ve done it once. My compliments go the the guys at Function First. Great product and great service also when I had some questions for them.:thumbup: |
are you on stock engine mounts?
Originally Posted by Dan GSR
(Post 13220959)
Another great diy emc. Thanks. Will probably give this a try. I too felt the shifting lost some edginess after the upgrade. Good for Dd purposes but not to enjoy the car.
Originally Posted by slicky rick
(Post 13223660)
I was able to really put things to the test today. I got to do some properly fast full throttle runs with high RPM up shifts, and a lot of aggressive downshifts as well. I can confirm this is no placebo effect. The transmission inserts REALLY make a difference. The shifting feels seriously sharp now...super precise. If you have a 997.2 PDK and you want to tighten up an already superb transmission, I can highly recommend this.:bowdown: |
2 Attachment(s)
Ive had a couple people ask about the sound since the install.
I've attached 2 files which are compilation of audio clips at varying speeds and on varying road surfaces. I tried to play around a bit with the throttle to highlight the great sound from the intake and transmission. At very high RPM's the exhaust does tend to drown out any other sound, but I think over the 3 mins of audio you'll get what I mean. The iPhone recording simply doesn't do it justice, but I think you'll get the idea. Enjoy! :thumbup: |
I have a manual 997.1 S and put these in a few months ago when I had my gear oil changed. Love it!
I have Wevo SS Engine mounts that I scored "barely Used" from a fellow RL'r and the combo makes for a lively beast. It feels very responsive and crisp on acceleration and shifts. Anyone looking to take some of the cushion out of their sports car should do this. |
Originally Posted by Hella-Buggin'
(Post 13228253)
I have Wevo SS Engine mounts that I scored "barely Used" from a fellow RL'r and the combo makes for a lively beast. It feels very responsive and crisp on acceleration and shifts. Anyone looking to take some of the cushion out of their sports car should do this. What stiffness inserts did you use? Did you also note an improvement in sound in the cabin? Of course when I say "improvement", that depends on what you like. For my use "improvement" means a little more like a race car :burnout: |
Originally Posted by EMC2
(Post 13231557)
Good to know HB.
What stiffness inserts did you use? Did you also note an improvement in sound in the cabin? Of course when I say "improvement", that depends on what you like. For my use "improvement" means a little more like a race car :burnout: And, yes, the grunt is an improvement. Between the motor mounts and the gear box mounts it's got a great growl. |
(Post 13231603)
I contacted function firay and Luka convinced me to go with the yellow street inserts. I track the car a bit but didn't want it to be unbearable on the street. I'm happy with his recommendation. And, yes, the grunt is an improvement. Between the motor mounts and the gear box mounts it's got a great growl.
With my PDK I got more of the transmission 'whine' that you hear in race cars albeit nowhere near as loud. That combined with the M&M Sports exhaust is intoxicating! |
Syncing the threads
(Post 4507824)
Emc after removing the single bolt di you lower the transmission to insert the "inserts". There is a black frame that the bolt goes through. This needs to be cleared before putting in the inserts. What was the procedure you did?
Once you have the transmission supported and main bolt removed, you then remove the 4 nuts from the lower carrier bolts (Part 2 on the Porsche Parts diagram). This allows you to pivot the carrier down just low enough so that it clears the OEM bushing area. (no need to fully remove it) You then Remove the nuts from the upper carrier (Part 1 on the attached Porsche Parts diagram). After that you remove the upper carrier studs. Once you have the studs out you can pivot the upper carrier forward and upward (toward the front of the car) so that it is out of the way. You may need to wedge something in there just to keep it from swinging back down whilst you are installing the mount inserts. There may be a way to fully remove this upper carrier but it really wasn't necessary at all so I didn't really try. In the pic below you'll see the black metal from the upper and lower mounts. The lower mount is already pivoted fully below and clear of the bushing. The upper mount in this pic was still a little in the way but it is easily pushed aside in the direction of the arrow. Hope this helps. https://cimg1.ibsrv.net/gimg/www.6sp...bcd2a67e5c.jpg + Rick - for completeness; I did not have to lower the transmission at all after I removed the main bolt. Note that I only had to raise the transmission a few mm''s to get the main bolt out. You can then get good access just by clearing the upper and lower carriers out of the way. Worst case I guess you may need to lower the transmission back to its initial position, but I wouldn't suggest any more than that. __________________ |
Excellent review and pictures!!! Very much appreciated!
Thanks especially for sharing your impressions with the PDK - several owners have asked about the Inserts' efficacy and impact with tiptronic & PDK transmissions vs manuals, so thanks for adding your perspective. Basically, every time the car shifts gears, there's driveline twist that the Inserts will minimize, allowing power to transfer to the wheels instead of getting soaked up by the mounts. |
Great write-up and review as usual EMC2 :thumbup:
I just placed my order for the yellow mounts. Will report back. |
Originally Posted by Function-First
(Post 13260242)
Thanks especially for sharing your impressions with the PDK - several owners have asked about the Inserts' efficacy and impact with tiptronic & PDK transmissions vs manuals, so thanks for adding your perspective. Basically, every time the car shifts gears, there's driveline twist that the Inserts will minimize, allowing power to transfer to the wheels instead of getting soaked up by the mounts. I went on a couple of good drives again this weekend and I'm loving the improvement.
Originally Posted by ATSR
(Post 13260418)
I just placed my order for the yellow mounts. Will report back. Great to hear. Please do let us know once installed. Is your's PDK or manual? |
(Post 13269832)
ATSR,
