Installed radiator grills, look great! Protect the radiators!
#61
Thanks again!
#66
#67
I just saw this thread, and have a question on the install for the side grills on a 997.2. I have a Zunsport center grille that I installed 2 years ago and love it, but apparently the installation for the sides grilles that mount BEHIND the fins requires the removal of the bumber
It looks like these side grilles mount behind the fins (which is what I'm looking for!). So what's the install DIY for these side grilles for a 2010 C4S Cab?
Thanks for the info on these!
#68
#69
I suspect ChicagoSpeed's current versions have evolved to be an even better fit, and I like this mod generally a lot. Good luck.
Ps it helps to use some child labor to install 😜
#71
Installed mine last night - a bit of tight fit on a GTS but I really like the final product. Now I need a center grill, but the GTS is different from other 997.2 models so I am going to make a template and send to Chicago Mike and see what he can do. Thanks Mike!
#73
Glad you like them Ralph! A suggestion, looks like the left grill could be shifted and the cable ties for the center can be placed under the horizontal bars to be hidden.
[QUOTE=porscheralph;13240500]Installed mine last night - a bit of tight fit on a GTS but I really like the final product.
See if you can shift the left grill to the left and re-cable tie, should look even better!
