Cracked windshield
Yea, i just went through this. $1200 or thereabouts. Choosing a specialized installer is crucial. You will see many posts about Safelite and others the are fully dependent on the actual person doing the work. Highly recommend calling the Pcar dealer and asking who they use. That is what I did and went straight to him to get the fix. They will ask for your VIN and whether you have tint/ radio antennas so be ready.
You might also think about getting Clearplex installed after you get that new windshield installed. I have taken a couple of significant rock hits and it has marred the Clearplex but the windshield is untouched. As a side bonus, my glass was getting a bit pitted and the glue from the Clearplex did a nice job of filling in the small pits and eliminating that afternoon glare off of the pits.
I'm curious about the Clearplex as I already got some pitting since picking up a 997 about 2 months ago and using it as my daily driver...
How hard was it to install the Clearplex (I assume you had a shop do the install)? Any imperfections like dust or smudges that are stuck below the film? Any bubbles or wrinkles? I did some research and it appears to be rather hard to install perfectly (much harder than paint protection film).
I agree with secondshot to use a professional.
I have seen examples here where the windscreen was not mounted flush to the bodywork but was "sticking out" several mm and the seal was therefore not sealing properly.
I did it in Europe last year at Porsche Center at the same cost as described above. With my insurence I paid 30% of the cost. Install of new windscreen was perfect.
Try to go OEM with professional installer. I switched insurance companies to safeco just because they cover all the glass for free without a deductible.
I just had mine replaced yesterday. it would have cost $1,350. Insurance paid for it with a $100 deductible. I had the insurance call my local Porsche dealer to inquire which glass replacement service they're using and the insurance then contacted them directly. They used OEM Porsche glass.
I replacement mine last year. Called all around checking on prices for aftermarket versus OEM. After reading many posts, decided to stick with OEM. The local Houston area dealership was less expensive than all others including Safelite, etc.
Yes I did have it done by a local shop. As I recall the cost was around $225 installed. I did find a couple of little of little, very small, dust bubbles after the install. It took about a week for all of the moisture to evaporate, the sheet is breathable and does let the moisture out. It became much clearer and less noticeable after a week or two. After a close inspection immediately after the installation where I found a couple of bubbles, I no longer notice them or suspect I could even find them. I suspect I will replace it again before too long as I have a couple of large bubbles now where I have been smacked good by rocks and it made it through the Clearplex. I'm thinking of it as pretty cheap windshield insurance...$75-$100/year.
I've seen many cars on dealer lots that had their windshield replaced and the quality of the install varied quite a bit. Like others said it's all about finding a quality installer.
In most states, it's the state not the insurer that regulates the cost of glass. Here in SC all glass is $0 deductible (windshilelds, side windows, reer windows - all of them). Call a couple body shops in TX and ask the question - also call your insurance agent since they'd be the one's processing the claim. If you're in a $0 glass deductible state, they also won't raise your rate for filing a glass claim. Also ask them about using OEM glass - just did this on my Infiniti even though it was over $400 more - no cost to me.
Whenever you have it done, after the windshield is set, the best thing to do is leave the car in your garage for a few days (the installers will tell you a few hours) and leave the side windows down, especially if you're not the only one with access to the car. If someone closes a door with the windows up before the adhesive is fully cured, it will push the glass up from the seal. Once that happens it will not cure right and you'll have nothring but problems with it.
