Tire Question
Read the tests. See how results are tallied. In one of the most quoted and referenced tire tests, MPSS won based on "subjective road noise'', even though the sound levels measured in decibels was lower on the Bridgestones. In another, MPSS won based on a subjective feel during a wet autocross.
I read the comparo tests, and many are tallied by morons.
The top several makes are so close in real-world driving that it's negligible. Also, you might want to buy 6+ MPSS tires, because if you need to replace one, it's gonna suck when they're always out of stock and you need a replacement.
I have had the MPSS's on two Porsches, and now also have them on a daughter's turbo MINI, and a Jag. While I cannot say how they handle at the limit, not having them on a track, they absolutely do last at least half again as long as some of the other brands on our cars. Which of course makes them cheaper, per mile driven.
All the best.....
NV
All the best.....
NV
Can anyone explain the difference between these two tires besides the $60.00?
I only need the rears, or I wouldn't be doing the P Zero's again, fronts are still good.
If you compare the two (Tire Rack) the only difference is OD and section width, how can that be??
The first tire has some sort of Audi-specific rating. The second tire has the Porsche N2 rating which is pretty demanding. There is some explanation of the requirements of N ratings here: http://flatsixes.com/porsche-product...hoosing-tires/
The difference: N and non-N rated tires of the same brand/type have a different compound mixture, possibly even a different sidewall construction... sometimes a slightly different tread.
Some say the 911 really needs those N rated tires, given the 911 is going to offer higher loads on the tires (for a variety of reasons).
It is also important to know that while Porsche N-specification tires have been fine tuned to meet the specific performance needs of Porsche vehicles, the tire manufacturers may also build other tires featuring the same name, size and speed rating as the N-specification tires for non-Porsche applications. These tires may not be branded with the Porsche N-specification because they do not share the same internal construction and/or tread compound ingredients as the N-specification tires. Using tires that are not N-specific is not recommended and mixing them with other N-specification tires is not permissible.
http://www.tirerack.com/tires/tirete...&affiliate=WC3
Just for the record, Tire Rack's article warns otherwise. Here is the applicable excerpt:
http://www.tirerack.com/tires/tirete...&affiliate=WC3Anyway, you vote with your dollars, if you need/want the N spec, go for it!
I really like how a premium brand like Porsche goes the extra mile to ensure a very specific compound can back up what the 911 is intended to do. R&D costs add up, then we all discard the the very specific but narrow edge such partnerships and development reveal.
Yes... we could all get away with non N tires (I suppose), but there's nothing like paying top dollar for premium brand (Porsche) only to forgo the little advantages built in by the premium development.
Yet MPSS (non N rated tires) are very highly valued by P-Car owners (although the 305s are not readily available) and the S04s (another non N-rated tire) are not a bad option as well (and are preferred over my N1-rated RE050A Bridgestones)!
I'm being sarcastic. I always argue that MPSS aren't worth the effort or grief when you order four and can't get a replacement later. S04's are just fine. Tire tests are often unrealistic, biased and lame.
I was being funny, because we all rip things out of a premium car and go our own way with things.
I also remember reading an article (might be the same one) that was put on by tirerack and a car mag that talked about how great the tire was, but tire rack aka useless other models of tires, so it wasn't a ploy to undercut all the other tires.
I am on michelins right now, but I wouldn't mind trying the bridgestones if the MPSS aren't avail at the time I need to purchase. Sounds like the performance is very similar.
I find it interesting that Michelin has been talking about getting N rating for the PSS but have not achieved this yet. I am sure they are great tires as they get prime ratings at Tire Rack and C&D. However, some tire comparisons I have read indicate that they behave differently when hot and respond differently to steering inputs compared to PS2s. I might try them in the future but from, I just got 4 new PS2s from Tire Rack and will mount them on my car today. Perhaps we are talking subtleties but I do want to maintain the handling characteristics as closely as intended so I handed over the extra $ for the PS2s. I do not know why but there must be some reason that the PSSs do not have an N rating for the 911. By the way if you buy tires (any brand) from Costco, Tire Rack etc, ( I am talking about non-N, Audi, etc. spec), they are not the same as sold by by car dealers. I was told this by tire industry experts, the construction and / or rubber recipes for the OEM tires are more optimized for comfort, mpg, etc even when the tire model number is the same
