997s deals around the interwebz (no affiliation)
Old 02-18-2019, 11:33 AM
  #4546
jazz11man1
jazz11man1's Avatar
Originally Posted by Fined
If you can get a full copy of that Carfax it will likely show the major services that have been carried out at a Porsche dealership. If services have been carried out at an independant shop they might not show up, that doesn't mean they weren't done. You've got to go at this like you care about what you're buying, be resourceful. Finding bits of info can lead to other bits of info. For example, if you see any entries on the Carfax that mention a local shop or Porsche dealership where work was done.. contact the local Porsche dealership(s) with the vehicle VIN to fill in any gaps in maintenance data you need. For example, if the car has two service records from Fort Wayne Indiana shops, find the local Porsche dealers nearby and call and ask them to verbally verify about some services carried out. Be prepared to get pushback when contacting a local Porsche dealership where the car was serviced, they may say they can't reveal any service information due to privacy reasons. Simply tell them "I don't need any information at all except to know what mileage XYZ was carried out or if you do not have record of it being done for VIN#________________)" You are not requesting them send you anything, just a verbal confirmation that a service was done.
Do yourself a big favor and learn all about the services that should have been done on the potential cars you might buy. This way you will have a general idea of the care of the car. A car which has not been serviced in a timely manner is a car that has not been cared for. Simple as that.
Maintenance schedule;
https://pictures.dealer.com/porscheo...419b79b522.pdf
Familiarize yourself with the maintenance schedule and use it to remove any cars that haven't been serviced to your personal standards.
If the car has all seasons on it, and expensive ones at that (Extreme Contact DWS are not cheap all seasons, they are pricey)..... the car was most likely used in all seasons. It may or may not be a concern to you. Seeing as greater care should be exercised for a 911 which has been stored in the cold or used in the cold. If what I've just mentioned isn't clear, spend some quality time on this forum reading about engine problems and proper warm up. Google is amazing too. If it's not a concern to you, well enough then.
To answer your question, no.. I do not think all season tires are a benefit on a 911 for my personal use. I haven't lived anyplace cold enough for them and I like to run high performance summers all year. ExtremeContact DWS are great tires (ran them on my TTRS) but they are a compromise as well. Soft sidewalls and crappy wear characteristics (they wear out kinda quick). Nothing wrong with them, just not my cuppa.
Do yourself another favor and don't use what a dealership tells you for anything. Just believe what you can verify yourself.
I stopped in and they showed me the full CarFax. It was scant on maintenance records. Contacting the dealer/shop is a good idea. As you mentioned, they said that it doesn't mean that the car wasn't taken care of since its not uncommon to not report to CarFax. Alternatively, I've talked to several people who have done most/all of the pre-40k (and even 40k) service on their own.
I would expect that the car has been used throughout the year, including in the winter, particularly given the tires. If two of the four tires are all-season and the others are summer, is it standard to put the all-season on the non-drive wheels?
I've read several threads on rennlist about engine failures for 997s driven in the winter. I don't have a sense of how significant of a risk this is, which is a bit of a concern since I would also use the car in the winter.
Old 02-18-2019, 12:09 PM
  #4547
Fined
Fined's Avatar
I do my own maintenance work on my car. But certain things I do not do. Items which require PIWIS or items which should really be seen on the maintenance history. For example.. I took my car to the dealer for the PDK service. As a buyer of a 911 myself, I'd want to see this service was done at a dealer. So I had my own done at a dealer.
It's not standard, no. Putting tires with different tread patterns at opposite ends of the car is idiotic in my view. This is a recipe for having something silly happen. You've got one sort of grip/wear/water dissipation at one end of the car and a completely different sort (due to tread pattern) at the other end of the car.
I don't think anyone at all (including famous engine builders) has a sense for how common it is.. because of the sheer number of cars that were produced vs how many have been seen in shops for engine builds. Even if we look at those seen in shops for engine builds, good luck trying to quantify how many of the failures were caused by misuse. Its simply not something that can be determined. We are on a web forum. Issues reported here will represent a fraction of issues occurred, there are other web forums and not every owner who had these problems will have reported it to the WWW. Issues seen in an individual shop will also represent a fraction of what has occurred. In addition, even if you counted every single failure that has occurred somehow (not even Porsche could manage to do this)... how will you determine which ones occurred from something the owner did or from the environment the car was used in or from god knows what else? Its a fools errand. Buy a car you're comfortable with.
My answers bolded inline.
Old 02-18-2019, 12:16 PM
  #4548
jazz11man1
jazz11man1's Avatar
Thanks. No I don't expect anyone to have a hard figure in terms of the rate of failure. I was referring to more of a very rough ballpark figure (e.g., I've seen the rate of 996 IMS bearing failures pegged around 10%, which is pretty high given the consequences).
For PDK service, are you referring to the 60k mile clutch oil change?
Old 02-18-2019, 12:26 PM
  #4549
Fined
Fined's Avatar
PDK Service - It's both time and mileage bound. Any 997.2 of any year or mileage should have had this service completed. I sent a link previous for the maintenance schedule. Check that out.
997.2 engine failures - very rough ballpark figure... how to come up with such a thing. What each individual will be able to determine is only what they personally know of. But the 997.2 was sold in many places on this planet. So again.. the data simply does not exist. Someone giving you a number is feeding his own ego for knowing something which is literally impossible to determine.
Old 02-20-2019, 01:13 AM
  #4550
rmstar
rmstar's Avatar
Just found this beautiful Miami blue 2012 4 GTS with 22,000 miles for $72,000 USD
https://wwwa.autotrader.ca/a/porsche...%201A7&sprx=-1
Old 02-20-2019, 10:15 AM
  #4551
8Lug
8Lug's Avatar
Great deal on 2011 Carrera S. $49,000 for a well optioned 32k mile car. Shows an accident but that could have been very minor.
https://www.alhendricksontoyota.com/...AB2A97BS720281
Old 02-20-2019, 10:32 AM
  #4552
mujeriega
mujeriega's Avatar
definitely a good deal for someone looking to drive and enjoy the car.
Old 02-20-2019, 10:35 AM
  #4553
Blackrock
Blackrock's Avatar
Saw this deal was interested and then saw the carfax. How do you really go about finding out what happened and what damage, if any, occurred?
Old 02-20-2019, 10:56 AM
  #4554
Tango Foxtrot
Tango Foxtrot's Avatar
Originally Posted by rmstar
Just found this beautiful Miami blue 2012 GTS with 22,000 miles for $72,000 USD
Nice car but that is a 3M wrap in Miami Blue.
Old 02-20-2019, 11:18 AM
  #4555
LISsailor
LISsailor's Avatar
How do you know that? From the vin? I am curious. And does the seller now know this as well? The listing is not well presented considering the asking price. What is with the mis-matched tail?
Old 02-20-2019, 11:29 AM
  #4556
vman932
vman932's Avatar
The description states it is a wrap. You can also see the factory color (silver) in the engine bay. The rear lid and wing are aftermarket carbon fiber.
Old 02-20-2019, 11:33 AM
  #4557
Flat_Six_
Flat_Six_'s Avatar
You could request the insurance claim packet which should include photos.
  #4558
LISsailor
LISsailor's Avatar
Thank you. I need more coffee.
Old 02-20-2019, 11:45 AM
  #4559
jazz11man1
jazz11man1's Avatar
One-owner and well-optioned (except for the steering wheel)
http://www.paulscarcare.com/BigSummi...25839A0062A2CD
Old 02-20-2019, 11:47 AM
  #4560
LISsailor
LISsailor's Avatar
Very nice spec. Imagine if it was manual.......................
Quick Reply: 997s deals around the interwebz (no affiliation)
