Suspected Lifter Noise After Auto-x Run
I suspect I have a lifter that is ticking right after I come off the auto-x course. I'm posing the question of why it is so noisy only after an auto-x run. The engine sounds fine on start up and regular street driving. Could it be oil starvation due to constant cornering? Lifter going bad?
Our auto-x runs are usually set up as flying laps with 3-4 laps per heat which equates to about 2-3 minutes or more of extreme cornering, acceleration, and braking all at once in one session. I've never noticed a drop in oil pressure at any time... usually 4-5 bars during throttle and hovering just over 1 bar at hot idle. Perhaps I need to cut my runs down to no more than a couple laps at a time...if oil foaming or oil starvation is actually causing a lifter to collapse from lack of oil pressure. This engine has 103K miles and I use 0W-40 oil. Perhaps a heavy weight oil like a 5W-50 would help. I'm just speculating at this point and trying to educate myself on the concept and operation.
I included an edited video of before and after my run on the course. The first 10 seconds you can hear the normal engine operation and then it cuts to the last portion of the video you can hear a distinct ticking noise that increases and decreases with engine RPM as I pull into my parking spot.
I don't see a video or link, just a large blank white square.
What's interesting is that the ticking seemed to lag behind the revs. When you blipped the throttle just as you were parking it seemed like it was a few seconds behind. Could it be a tensioner or something belt related that is not as quick to react?
I can double check all my pulleys but they were good when I checked 3K miles ago. I would think a pulley would be something constant but I could certainly pull the belt off and make sure. I've driven the car this week and even to work today and it sounds fine with no audible ticking.
I'm going to stop by Harbor Freight and pick up a stethoscope and play doctor with the engine this weekend. I really suspect it's a valve train noise.
I was't thinking the actual pulley so much as something in the belt/ pulley system. Alternator, AC Comp, tensioner wheels.
Tandem secondary oil pump/vacuum pump in the lower right side of the engine? It pumps oil to the right bank of lifters. I had a ticking noise that increased with engine rpm's in that area, slight lag like you describe, loudest with the mechanics stethoscope on it's cover. But my noise was present with the engine hot or cold, loudest when starting a cold engine.
The other secondary oil pump is in the left front of the engine.
Porsche 997 Engine Sound - YouTube
Also, think about it. If you think its oil pressure related, then why would it be making more noise after the run? It should be noisy during and quiet afterwards, right? So its not that.
If it is valves (if) then it could simply be one getting a little noisy when the temp goes up, as it probably does during a run. If its gone when you restart for the next run, well then there you go.
Try holding the RPMs at a few thousand RPM after the run, in neutral. If the noise goes away with the oil pressure it's likely a lifter stuck. Coming from the E36 BMW world, it's a common issue for us. Some guys overfill the crankcase a bit and it helps. Not sure if that translates well into these engines, but something to consider.
Good information everyone. Thanks. Going forward I will continue to keep an eye (ear) on it.
Hot and sticky lifters would make a great name for a rock band.
Just an update, I changed my oil to 5W-50. Ran our auto-x last Sunday and I never had an issue with any lifter noise after each run. Each pass was only @ 80 seconds so that is shorter time than our usual 3-4 lap events but so far so good.
