#WC09 Voluntary Service Action - Replace Clutch Pedal Switch (997.2)
I recently received a notice from myCARFAX regarding this recall: has anyone else been advised of this notice?
I haven't been advised of it but mine was just replaced a month or two ago. They had the part in stock and said they go through pretty quickly. I'm thinking this is a known issue.
That switch has been a problem since they started using it with the 996-
Once the metal arm fatigues- it sometimes looses contact.
In a pinch you can also Carefully bend it back so it is closer to the clutch pedal. I carry a spare in my door pocket. It's just held in place with a PIA screw and a connector for the electrical
I was unaware of recall but I did just get this fixed a week ago.Here is the link to an old thread that describes my problem.If this is the same issue as recall it certainly has been known for quite a while.
What is BS is trying to start your car a couple of times unsuccessfully while your prompted to fully depress clutch pedal when you know damn well you already are!
https://rennlist.com/forums/997-foru...carrera-s.html
Thanks for all of the feedback!
I've pinged my SA and will report back when I learn more...
Here is a thread that references that "recall":
https://rennlist.com/forums/997-foru...n-ongoing.html
I'll ask my SA about WBO8 when my 997 goes in for service to replace a leaking front axel seal.
I've learned that the WCO9 campaign was accomplished by the original owner.
