LED Interior Kit Install this weekend
I purchased the LED Conversion Kit from Suncoast this week and plan to install it this weekend. This will be my first project on the Pcar.
In reading a few other threads here, I know that these cars have sensitive electronics and i would HATE to get into a "which fuze is blown" scenerio. Do you guys think I should disconnect the battery prior to replacing the lights? Thanks in advance for any advice. |
I do not recall disconnecting the battery, just change the bulbs out. Mine made a big difference, this mod was well worth the money.
Good Luck!!! |
+1, not necessary to disconnect the battery
Also be sure the LED's light up before putting it back together. Unlike regular bulbs, LED's have a polarity. If it doesn't light, rotate it 180 degrees. |
This thread is useless without photos of your car.
Any picture documentation would be very helpful. I'm doing this in the spring.
They have instructions on their website (see here). Thanks for the feedback on the battery. I'll snap some pics of my progress when I do it.
Very easy and very much worth it. I changed out my tag lights for LED at the same time I did the interior. I think you are going to like it a lot when you get done.
2 Attachment(s)
I installed my LED interior kit from Suncoast not too long ago. I did not have to disconnect the battery. All you need is a pocket screw driver and a plastic pick. I used this as a guide
Best interior mod you can do to these cars. I don't know why they didn't come with them standard. Sorry for the crappy pics. |
As others have already stated, you do not need to disconnect the battery. I did this same mod about 9 months ago and love the resulting increase in interior lighting.
perhaps a dumb question, but can be done to 993 & 996?
Thanks!
Thanks for the video Supermode. The video is way better than the static PDF they supply for instructions!
I'm happy to hear that everyone loves the mod. I actually have a the driver's side dome light out so this will be a dramatic improvement in interior light. |
Originally Posted by hammerdown
(Post 12015515)
Originally Posted by espanolie
(Post 12013757)
If you change the front light in the front trunk, be careful because that one is sensitive and mine shorted out, which I discovered is not tied to a fuse. Its tied to the control module and that has to be reset. Other than that one, the others are easy, quick in and out.
Originally Posted by pkancel
(Post 12018588)
Can you elaborate on being careful? I changed all my bulbs to LED with a cheap $30 kit from ebay. The map lights and one of the footwell lights shorted out. They actually burned. The heads of the two map lights separated from the base, that's how hot it got. I kind of expected this since the kit is cheap and the install was a pain because the 194 bulbs had to be seated just right or they wouldn't come on. However, the frunk is a festoon bulb and there isn't much you can do regarding the contacts. I replaced the 194 wedge bulbs with higher quality bulbs from Amazon and they fit perfectly without having the adjust the bulb in the holder. |
