Considering a mid-rise lift - Bendpak? Harbor Freight?
I have the Bendpak lift. Works great. Clearance is an issue but easily resolved using some 2 x12 x 16. I have them as ramps running along the lift. Two stacked on top of each other 4 total boards. Tried to add a picture, but something isn't working right with the forum page.
I just bought BL5000 for my 997 but the hoist point on the car is 6 inches away where the BL5000 rear lift point is so I am a bit lost as what to do, can you send me pictures of your setup please.
Or, remove the rubber blocks, center the BL5000 thus making just a 3" overhang on each end, and lay a wood beam?
Honestly, I think you should sell it, return it, and just get a better unit more suited for you car.
Peace
Bruce in Philly
returning it would not be sensible since I have to pay for shipping and do not have the boxes, I guess I can sell locally since its a month old, what a shame I was excited to get this working. oh well thanks for your help anyways.
Bruce check out my solution for my BL5000, hehe it worked great I am so happy $1300 did not go to waste
Video Link: https://www.youtube.com/watch?v=zP24ru8SdBc
better you than me... no way would i do that. center of gravity looks off. maybe to change a tire but i wouldn't get underneath that to try to change plugs without getting a jack stand. i would probably get someone to also weld side plates and figure a way to attach it back to the main plate.
Richard181 you are absolutely correct, point well made, I was concerned about center of gravity as well. I like your setup and I thought about doing built in but don't know i will be staying at my residence for a long time and that would be a waste of investment.
I am sure if I speak to BendPack they will not provide any input since I have changed the design of the lift.
I even thought to reverse the lift and put the weld plate in the front where front of the car is lighter than the back but I still don't think that would help center of gravity and the lifts stability since it was not designed to be that long.
I will probably look into suggestion that Wayne made I will check with my welder. I guess for total safety if I want to get under the car while lifted I could put jack stands under the axles as a precaution till a more solid solution.
thanks for the inputs Gents
Bendpak all the way
I have friends that have the mid-rise, 4 post and 2 post lifts from Bendpak and they have been very happy with them. My friend Chris has 2 4post lifts and a mid-rise and has never had an issue with any of them.
Check out garage journal they have pages of post on the Bendpak lifts.
http://www.garagejournal.com/forum/
Also when I was at the Porsche Driving School at Birmingham Al. they were using a Bendpak midrise lift. When I get home I will try to find the pics of it
