Windshield Washer Pump? (help)
So I thought I was low on washer fluid... just filled it up and turns out nothing is still coming out of the windshield washers when I pull the level forward. I figure the pump is broken... but curious if it could be something else, fuse?
Any help to diagnose the problem appreciated
If it's the pump, anyone know where I can get directions on how to change out the pump?
Thanks!
Thanks!
Try pulling the driver side wheel liner back a bit after you pull the front tire. You can see the hose/pump connection. That would happen on my 996 after a track day. If that is it just slip the hose over the plastic nipple and you are all set.
