Flashing lights when returning to locked car
Old 10-02-2014, 08:09 PM
caitov
caitov's Avatar
Default Flashing lights when returning to locked car
I've been searching and trying to figure this out but I'm stumped.
Twice in the last week when dropping my son off at school I've come back to my car and noticed the rear lights flashing (I assume the fronts as well but I didn't notice). As soon as I push the key fob they go out.
It's not constant as I've never noticed this when going to my car after work.
The only thing I can think of that is different is when dropping him off I'm locking the car after closing the passenger side.
Also, the horn isn't honking so I assume the alarm wasn't triggered.
I did have the sunroof tilted open today, but couldn't find any reference this being an issue.
Any ideas?
Old 10-02-2014, 09:25 PM
jhbrennan
jhbrennan's Avatar
Any ideas?
Try looking in the owner's manual (page 24 or thereabouts). Here's an excerpt:
If one of these alarm contacts is interrupted, the
alarm horn sounds for approximately 3 minutes.
Additionally, the emergency flasher flashes and
the passenger compartment light lightes for approximately
five minutes.
When the alarm is triggered, the light-emitting
diode changes over to double flashes.
Sounds like the alarm was triggered.
Old 10-02-2014, 10:15 PM
caitov
caitov's Avatar
Thanks, but I really don't think it's the alarm as I would've heard the horn. It seems to be lights only.
Old 10-06-2014, 01:27 AM
Petza914
Petza914's Avatar
Received 6,128 Likes on 3,903 Posts
Have you popped the hood or tried to unlock the car as you were approaching. If you did either of those, and didn't open a door within 20-30 seconds (I think) the car will relock automatically and give you the double light flash. When it does this, it won't honk the horn unless there's a circuit open (hood, glovebox door, etc). Maybe you're timing your approach just right after initially unlocking it, to witness the relocking and light flash.
Old 10-06-2014, 10:31 AM
StormRune
StormRune's Avatar
OP, the wording in your last response almost makes it seem as though you didn't read JHBrennan's response carefully. According to what he wrote, the horn turns off before the lights stop flashing. There was a two minute window where you could have walked out to find the lights flashing with no horn beeping.
Or are you saying that due to your proximity to the car the whole time you would have heard the beeping in any case?
Old 10-06-2014, 04:16 PM
caitov
caitov's Avatar
Thanks, but the lights are flashing continuously, not just a double flash. I am also away from the car for more than 20-30 seconds.
Or are you saying that due to you proximity to the car the whole time you would have heard the beeping in any case?
Yes, the latter. Based on where I am I'm almost certain I would hear the horn if it had gone off. That's why it's got me so stumped.
Having said that, I know these aren't the loudest horns. I'll keep an eye on this and let everyone know when it happens again.
Thanks for the help.
Old 04-25-2019, 03:28 PM
AM6007
AM6007's Avatar
Apologies for bumping an old thread. Did OP figure what it was finally ?
Old 04-25-2019, 03:38 PM
Petza914
Petza914's Avatar
@Wayne Smith had this same or a similar issue, but I don't recall how he resolved it. May have simply been a new battery.
https://rennlist.com/forums/997-foru...indicator.html
Old 04-25-2019, 05:49 PM
caitov
caitov's Avatar
I never did find out what caused it, and it stopped occurring, so I just kind of forgot about it.
It wasn't the battery however, as I only just replaced that last year. I assume it was some type of alarm trigger having to do with the passenger door being closed last. It did that a few times over the course of a month, and haven't had any issues since.
Strange..
Old 04-25-2019, 06:37 PM
Wayne Smith
Wayne Smith's Avatar
Received 1,139 Likes on 724 Posts
In my case the flashers would sometimes turn on immediately when I shut the car off. Sometimes they would turn on several minutes after I shut the car off. They might or might not turn off when the car was started. I tried a new battery. No luck. Finally replaced the front controller to fix it. But this case doesn't seem to bed the same as mine.
Old 04-25-2019, 07:02 PM
Phrog Phlyer
Phrog Phlyer's Avatar
Ignition switches do strange things when they are going bad/getting old.
Old 04-25-2019, 09:05 PM
Wayne Smith
Good point ... A problem for VW in the 90s.
Old 04-26-2019, 12:21 AM
AM6007
AM6007's Avatar
Thanks for the replies guys. Gonna have a poke around with the doors/sunroof before heading to the dealer.
Cheers, have a good weekend !
Old 04-26-2019, 11:12 PM
AM6007
AM6007's Avatar
Thought i'll update you guys with what the issue was in my car. It was the alarm siren shorting out. Easy check, if one of your passenger doors/hood/rear engine cover/sunroof isn't fully closed and you press lock on the key fob you should hear a chirp along with a flash of the hazards. If you don't hear a chirp, you're going to need a new alarm siren/module.
Old 04-27-2019, 01:09 AM
Wayne Smith
Thanks for the update 8)
Quick Reply: Flashing lights when returning to locked car
