Used My Collapsible Spare Tire
#31
Just out of curiosity for a nail (not near side wall of course) what would be best Fix a Flat can of aerosol or Slime? I believe both of them say they do not damage TPMS, just want to know what would be best. I would much rather use that as a first option than a collapsible tire for a nail.
Thanks for advice.
Thanks for advice.
#32
Thanks for advice.
Thanks for advice.
#33
I would recommend a tire plug kit like the picture below. They sell for less than $10 at most major auto supply stores. I keep one in my frunk just in case. I prefer to use this method over the slime in a can, especially when I can locate the source of the leak.
Sean
Sean
#34
I keep all of the above: p-spare kit, plug kit, FaF, and slime.just gives me more options to chose from to cover all situations. FaF and slime are typically my last resort.... Used it once several yrs ago for a quick fix so that we could still make it to a ball game in time. It made a 2" wide slimy mess on the inside of my wheel well. Basically sprayed FaF goop out of the hole made by the metal debris shank that had dug into my tire. I spent a good hour cleaning out the inside of my wheel liner then another hour cleaning the goop off my exhaust where it was baked on. It got us where we needed to go on time but of all the options available... It is my last go to. BTW leave the nail in the tire if you have to go this route.
#35
Carry a pair of side cutters (wire cutters) if you use a plug kit. I worked in a service station when I was a kid and plugged hundreds of tires. You have to cut the plug down below the level of the tread, or the friction from the road will tear the plug out and you will have a flat again.
