Show me your 997 with non-Porsche wheels
#76
Was just scratching my head over that picture. That's the exact opposite wear pattern of what's the norm. Almost looks like the tire has been rotated.
#77
Yup, usually people lower their cars with a set of coilovers and then don't change the rest of the suspension components (rear dog bones & toe steer kits) and can't achieve the proper alignment spec, badly wearing the inside edge of the tire, but this one is worn on the outside. Like you say, maybe it was rotated, but it would have to have been a dismount and remount due to the staggered setup of these cars. With wear to that level, I wouldn't think that's worth the expense to dismount, remount, and rebalance. Maybe Poparelly can shed some light for us.
#78
#79
That pic is a little old. I have a few thousand miles on my PSS that I put on a little over a year ago. I'll take a pic and post it. I'd like to get your opinion on the current wear pattern. I didn't think my car had any suspension modifications (bought pre-owned), but it would make sense if if had some TechArt springs since it came with so much other TA stuff. Does the ride height look lower than normal for a 4S cab with PASM?
Also, I had an alignment done when the new tires went on.
#80
On the 997, I'm doing the dog bones and toe links so I won't be doing that on this car.
MrTickles (06-30-2019)
RABjr (03-08-2021)
#85
You're right. Just looked at my PSS's and it only says "outside" on the sidewall so you could rotate them for even baldness all around before replacing. Could have sworn I had a set of tires that not only had "Outside" marked but also a directional arrow. Or maybe it was only a directional arrow on one sidewall indicating it was only intended to be mounted on one side of the car and not the other.
Thing2&Thing1 (06-30-2021)
Max3480 (01-09-2022)
