Ac evaporator cleaning
The evaporator is the radiator like object that cabin air is routed through to cool and remove moisture from the cabin air or that is air that will soon be routed through vents to the cabin.
Generally the evaporator is "buried" in the A/C system/unit that is located under/in front of the dash.
The condensers at the front of the car located in front of the radiators are to cool the compressed and hot refrigerant to the point it turns into a liquid.
A/C lines carry this fluid to a low pressure region of the A/C system where it turns into a vapor. In doing so it cools down. At this point it is probably in the evaporator -- hence the name -- where incoming air is able to give up its heat and moisture.
After the evaporator the refrigerant now warm and in vapor form once more is routed to the compressor which compresses it and heats it and then it is on to the condensers and so on.
Evaporator Cleaning
I saw a presentation on Motorweek that covered this with a product called Frigi Clean recommended for use once a year.-
http://www.motorweek.org/features/go...ac_maintenance
Frigi_Clean has an adaptor that comes with it that gets installed in the housing under the hood and then the foam from this is injected through that adaptor and it just floods this whole evaporator area, cleans it. Cleans it like brand new. Makes it last longer, and does away with the odor.
Porsche's thinking is probably that if you filter ALL airflow entering the passenger cabin then there will be little need to filter recirculated air.
"in fact it is NOT recommended.."
Not recommended, even hazardous in climates/periods requiring cabin HEATING. Recirculate use in those conditions often results in rising Rh due to body metabolism, windshield begins to fog up, sometime suddenly.
Counter that with the fact that A/C can be much more efficient for strictly cooling inn recirculate mode.
Not recommended, even hazardous in climates/periods requiring cabin HEATING. Recirculate use in those conditions often results in rising Rh due to body metabolism, windshield begins to fog up, sometimes suddenly.
Counter that with the fact that A/C can be much more efficient for strictly cooling in recirculate mode.
Evap System Diags from PET
Peace
Bruce in Philly
You know, as I look at that diagram again, I may be misunderstanding it.... it appears the heat exchanger, 2, slides into 1.... it may not. The heat exchanger is in a cowling in the front trunk and may sit in front of #1 which sits on the other side of the "firewall" behind the dash. That section 1 may have the evaporator coils in there and are hidden in the diagram. But where are the hookups for the AC lines?
The description of 1 specifically says the evaporator is included.
Peace
Bruce in Philly
Bruce
Peace
Bruce in Philly
Bruce
Anyways back to my original inquiry. Anybody try out those coil cleaners in a can that you just spray on? Do they work in cleaning the evap, without actually removing the whole system?
I hated the smell...... my car smelled like a purple caddy with full hydraulics that lasted a few weeks IIRC.
It did not work, but the problem was a leaking heat exchanger and the smell was actually antifreeze. You would think mechanics would recognize the smell, but they did not. It had a musty, maple syrup smell.
Peace
Bruce in Philly
Many were not conducive to human life.....
Be careful......
Resurrecting this thread. Has anybody cleaned their evaporator without dismantling the dashboard?. Anybody use the evaporator cleaners in a can? In our cabin there are two heat exchangers 1 is the heater heat exchanger where coolant from the engine flows. This is used to heat the cabin in cold climate areas. The other heat exchanger is the evaporator that flows refrigerant used in hotter climate areas. The heater is easily removed from the front i believe. However the evaporator for cooling is a separate issue needing extensive dismantling and lots of labor hours. To avoid this expensive maintenance service there are some suppliers who now use cleaners in a can that are injected through the housing to the evaporator to clean and disinfect it. I just don't know if it's effective...
