Question/advice on OBD error message
Just took my '05 'S' to our local environmental test station where we must test our cars. The gauge cluster was NOT functioning because I had fiddled with it and hadn't pushed the wire harness all the way home. The OBD test read error code P0074, which according to the AirCare web site is: "Ambient air temperature sensor circuit 'A' intermittent/erratic". Could this be because the gauge cluster was not connected. I know the cluster has an outside ambient air temperature reading on it--which obviously wasn't working.....? The gauges work fine now, but I don't want to pay another $25 just to receive another error message. Anyone know anything about error code 0074?
I had a similar experience. Removed the cluster to paint the trim. During reinstall, the connector was not pushed all the way in so no activity on the cluster. Drove the car and the sport mode and PASM buttons would not activate. After resetting the connector on the back of the cluster, everything returned to normal. No error codes showing with Durametric now either.
Any local auto parts chain store can do an OBDII scan for you for free. Perhaps start there. Another option is the ELM327 Bluetooth OBDII dongle from eBay (go with the small v1.5 version) and the Torque Free app running on your smartphone. This is a really cheap and powerful OBD scanner setup (less than $10).
That's what I wanted to hear--exactly! Thanks for that, semicycler. I'll assume that the error message has gone away now that my gauges are up-and-running.
doesnt tell you much and sounds like your issue sorted itself out but FWIW:
P0074
Fault entry in specified control module (in your case, the Ambient air temp circuit, i guess)
Note!
Internal function test completed.
Diagnostic conditions
The control module initially tests internal function sequences after wake-up. If they are OK, all diagnosable outputs are then tested and any faults are stored.
Control module wake-up through:
--event-induced CAN message
--wake-up signal via wake-up line
--key contact (terminal S)
--"Ignition on"
Possible fault causes
--Control module is incorrectly coded
--Periphery connected to specified control module is incorrect
--Control module faulty (in most cases the cause is not the control module but incorrect coding!)
Fault effects
--The specified control module sends only substitute values via the CAN.
--Other control modules detect these substitute values and set this fault code.
P0074
Note!
--"Ignition on"
Fault effects
Also, in my area Autozones and Pep Boys will read the code for free.
