Shakey Passenger Seat When Empty
Old 02-22-2014, 03:42 AM
JCD911S
JCD911S's Avatar
Default Shakey Passenger Seat When Empty
Is it just my car, or does the back rest of your passenger seat shake while driving with the seat empty? Don't know if I should bother trying to fix it, if at all fixable.
It always catches my attention and gets kinda annoying. Doesn't shake too bad, but enough to be noticeable.
Old 02-22-2014, 03:54 AM
Khaim3
Khaim3's Avatar
My does the same. I think something is not right
Old 02-22-2014, 05:59 AM
rankoutsider
rankoutsider's Avatar
I had the same issue and found a bolt had worked its way loose. Had a chat with the Porsche Centre guy and he said that it happens occasionally.
You have to take the seat out - pretty easy. Its a good opportunity to clean underneath it. I found the previous owners watch - not a bad one either. So you never know.
See below
Old 02-22-2014, 09:23 AM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,653 Likes on 986 Posts
Excellent, thank you..... I will do this next time I have a few hours.....
Peace
Bruce in Philly
Old 02-22-2014, 10:21 AM
seahull
seahull's Avatar
I had the same problem when I bought my 2008 a few months back.
The bolt shown in the diagram acts as a pivot, so moving the seat bottom up and down applies twisting force to undo it. After searching for the lost bolt and washers on the floor under the seat and reinstalling them, I torqued it down as tight as I could with a standard Allen wrench.
Old 02-22-2014, 11:32 AM
Function-First
Basic Sponsor
Function-First's Avatar
Excessive passenger seat shaking may also be indicative of your engine mounts going bad. The rubber in the mounts wears and sags over time and no longer properly dampens drivetrain vibrations.
Comprehensive Shifting Solutions for your Porsche.
Old 02-22-2014, 11:57 AM
JCD911S
JCD911S's Avatar
I suppose this is possible but I'm only at 27k miles so not likely. I do think the aftermarket exhaust is adding to vibration tho. and I still may be interested in your mounts for less slop in the engine and gear box shifting.
For now I'll give the seat bolt tightening a shot. Thanks for the info guys.
Old 02-22-2014, 12:33 PM
mdrums
mdrums's Avatar
As tires wear the balance of them changes slightly. You can hardly feel this but as the slight vibration travel you can see them in the seat back shake. Also different road surfaces can accent this.
Old 02-22-2014, 02:03 PM
One911
One911's Avatar
Mine does this at idle only
Old 02-22-2014, 05:09 PM
Lvt19672
Lvt19672's Avatar
So the seat needs to be removed to tighten this bolt?
Old 02-22-2014, 06:30 PM
997v2cabrio
997v2cabrio's Avatar
hey rankoutsider how does one get a detail image of the maint of our cars?
Old 02-22-2014, 07:34 PM
Edgy01
Poseur
Edgy01's Avatar
This is completely normal. The issue is not engine mounts, or anything like that. It has to do with how well peened the seat rails are which will impact the seat's ability to slide through the rails. The loosen they are, the higher the probability that they will vibrate when empty. I know, it can drive you nuts sometimes. We addressed this several years ago.
Old 02-22-2014, 10:21 PM
Lvt19672
Lvt19672's Avatar
+1 if you change your motor mounts to a stiffer one the vibration and shaking will be even worse.
Old 02-22-2014, 10:44 PM
chris.hanle
chris.hanle's Avatar
Remember if you remove the seat and disconnect it (the airbag weight sensor) you will need to reset the airbag light with a durametric/piwis or possibly an ob2 tool(not certain the ob2 will work,,but I think it will). I don't want anyone to trade a squeaky seat for a bright light.
Old 02-22-2014, 11:45 PM
Function-First
Basic Sponsor
As long as you don't turn power to the car on during the process, the airbag light won't get tripped.
8x57IRS (11-30-2022)
Quick Reply: Shakey Passenger Seat When Empty
