997 Forum
Oil Change at say a Jiffy lube?
Old 02-17-2014, 12:35 PM
  #31
Macster
Originally Posted by LexVan View Post
Will a JL let the car sit in a bay for the 20-30 minute drain interval?
If I were concern about oil change costs, I'd force myself to learn DIY before I'd go to JL.
For the DFI engine the minimum drain time is 1 hour provided the engine/oil is up to some minimum temperature (170F or higher).
Macster is offline
Old 02-17-2014, 12:45 PM
  #32
Macster
Yes, some are that bad. While the oil change is a DIY task it is not a task without risk if the job is done improperly.
There are many ways to screw this up and this quicky lube joints have I think found almost all of them.
I took my Boxster to one quicky lube place. It should have known better when I had to point out where the engine was to the techů
Short version is the tech didn't insert the tool bit deep enough in the drain plug and he buggered the drain plug so when I took the next time the car needed an oil service and I took the car to the dealer the tech had a heck of a time getting the drain plug out of the pan. He managed but I had to replace the drain plug. This was a drain plug that had lasted years and years with uncounted removals/installations from both a dealer tech and myself.
The drain interval wants to be of a specific duration. Then the tech adds the exact amount of oil -- as per the factory manual or TSB or whatever -- not what is listed in the owners manual! -- and verifies the digital e-oil level display reads the proper level. This is the only opportunity to check this against adding a known quantity of oil to an engine that has been properly drained of its oil.
There are more than just the oil and filter to worry about. The oil drain plug seal washer needs to be replaced. The oil filter o-ring needs to be replaced. The o-ring needs to be checked to ensure it is in the o-ring groove and not in a thread where it can catch and be cut and result in a leak, or a filter housing that is not installed properly.
There is to the concern about over tightening things. One quicky lube joint informed me that its corporate rules required it to torque all drain plugs down to 50 ftlbs. Well, that might work for some old Detroit pick up truck but not for my Boxster engine's drain plug and not even for my GTO's drain plug.
Macster is offline
Old 02-17-2014, 01:53 PM
  #33
Chrono
Chrono's Avatar
Does anybody know how to use Norton Utilities?
Chrono is offline
Old 02-17-2014, 02:46 PM
  #34
iammulva
User
Yes, many ppl do.
Sorry, couldn't resist. Wrong forum though.
iammulva is offline
Old 02-17-2014, 03:29 PM
  #35
997_Toronto
User
997_Toronto's Avatar
Yes, it's one of the worst designed products, it's a resource hog and causes more problems than helping keep things running smoothly. All you need is a decent firewall and an antivirus for a home machine.
PS: It does not help with oil changes on your P-car
997_Toronto is offline
Old 02-17-2014, 04:21 PM
  #36
GSIRM3
Super User
GSIRM3's Avatar
Originally Posted by Jaws1 View Post
Most use pits, not lifts. The 997 oil change is really simple, but that being said, if something can go wrong a quick lube place will figure out how to make it happen. Just find an indy.
Exactly. Like cross-threading the drain plug or over torquing it and stripping it.
GSIRM3 is offline
Old 02-17-2014, 09:45 PM
  #37
Lance-AR
User
Lance-AR's Avatar
I changed my 997 oil on a completely flat surface without the aid of ramps or a jack. It was worth knowing I had properly torqued everything myself.
Lance-AR is offline
Old 02-18-2014, 09:11 AM
  #38
targaC4S
User
targaC4S's Avatar
Had your torque wrench recalibrated in the last 6 months? Haha jk
targaC4S is offline
Old 02-18-2014, 06:58 PM
  #39
stronbl
It's been said several times already, but can't be repeated enough IMHO - caution due to improper threading of drain plug into oil pan, leaky or missing crush washer, over torque drain plug, and rounded hex head in drain plug. Common problems on any vehicle at a quik lube place, but especially a potential issue with 997's & 991's and the AL engine parts.
stronbl is offline
Old 02-19-2014, 08:45 AM
  #40
Smitten
Smitten's Avatar
Early in this thread, somebody said any competent mechanic can change oil. While that's certainly true, there are no mechanics at the quick lube places. None. Zero. Let alone competent ones.
I took a new 4Runner into a JL. I was on the road, far from home, and still had a couple thousand km ahead so I didn't want to let it go too long. The kid in the pit was barely ok with cars he knew but totally over his head with any vehicle he hadn't seen before. The thing that pi$$ed me off the most was that they only looked for the filter after they had dumped my oil. And I had to get in the pit to show him where the drain plug and filter element were, and how to get to them behind the skid plate.
Smitten is offline
Old 02-19-2014, 09:46 AM
  #41
thekubiaks
User
thekubiaks's Avatar
Originally Posted by myw View Post
wow is jiffy lube THAT bad?
i figured the oil change is DIY level of difficulty so i figured it wouldnt be a problem.
Yes, they are that bad. I took a Honda Accord in for an oil change because I was in a hurry. I then drove the Honda home with my wife following me. She called and said the Honda is smoking. The dumba$$es overfilled the oil by a whole quart.
Would I take my 911 C4S to them....NoF'ingWay
thekubiaks is offline
Old 02-19-2014, 10:10 AM
  #42
PhilD
User
PhilD's Avatar
Only time I used JL was for a H1 when I was out of town, no problems at all. On the other hand the Hummer dealer failed to tighten the oil filter one time and I had dumped all the oil 800 yards from the dealer. You can find incompetence any where. That said, JL would not be on my top 10 list for a Porsche oil change. If you don't want to do it yourself and want to save some money find an indy that at least has worked on p-cars before, the ones that specialize in European or German cars are likely a good bet.
PhilD is offline
Old 02-19-2014, 11:53 AM
  #43
hot nikon
User
hot nikon's Avatar
My indie guy did mine last week, $150.
AND, checked underside, wheels.
A good indie is a blessing.
hot nikon is offline
Old 02-19-2014, 02:13 PM
  #44
too tall
User
At the risk of piling on. When I first read this thread what immedately comes to mind is "I'd rather claw my one good eye out slowly with a pickle fork".
It is your Porsche you do what you want.
too tall is offline
Old 02-19-2014, 03:40 PM
  #45
Fahrer
User
Fahrer's Avatar
Several years ago, I took my 1999 Audi A6 to Jiffy Lube once because I was headed for a long drive vacation and could not get a near tem appointment through the Audi dealer for an oil change. No probelm, they had a suitable oil and off I went with no problems. The next oil change, I took it to the Audi dealer, as usual. After completing the service, they informed me that half of the screws holding the under body faring to the car were missing. This panel must be removed to get to the the oil drain. I guess it cold have come loose and caused some damage but I was lucky. Never again....
Fahrer is offline
Quick Reply: Oil Change at say a Jiffy lube?
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
