Battery maintainer?
thanks
I don't have the box or part number but it's the Ctek comfort indicator. So it at least fits my Ctek 45 and some more models with the quick connector. It's in Europe so I'm not sure it's the same name in the U.S. though. Price in Europe is at 15 dollars.
In the picture it's the one to the top right (if you tilt the screen ). I have the one with eyelets and have mounted them fixed to the battery terminals. It even includes a fuse. The light is blinking green, yellow or red depending on battery voltage.
I would really have liked the panel version but I will never carve a hole in the plastic of this car so that version was ruled out.
Just another option to consider to make monitoring the charger easy. Mine hangs from the ceiling near the door with a hook to hold the cable when I'm not using it and where I can see the status light when passing through the garage. When hooking it up it is just a matter of cracking the window and plugging it in. Please excuse the messy garage in this photo. The status light shows it is charging (since I just plugged it in):
Is there any kind of back up battery that can provide additional charge inside the trunk and without an external power source? I live in a condo and there is no way to have a battery tender or externally supplied power source to the batter. But something that would give the standard battery an extra supply of power to run the computers for three weeks or so would be ideal. Anything out there like that?
For me (also a CTek) I have to make very certain the charger is firmly plugged into the receptacle. If it's not in all the way just right, I don't get the connection I need. Seems to be a subtle difference between in and out sometimes.
I just Googled and found this page:
http://www.batterystuff.com/solar-chargers/
I noticed now with the battery indicator connected that as soon as I unlock and open the frunk it goes to yellow. Also, if I unlock the car and open the doors it goes to red (all interior lights and GPS DVD running etc). Maybe my battery is starting to get close to end of its life. I still have what I believe is the original MOLL battery in the car.
As soon as I lock and close all doors it goes back to green again.
So, it could be worth knowing that the interior lights and DVD etc seem to consume a substantial amount of power. If you measture the battery voltage it is probably wise to do it with only the frunk open and everything else closed and doors locked. Anyone else have the same experience?
I think the only options you have are to disconnect the battery, take it in with you and hook it up to a maintainer. The car battery should last 3 weeks. Just buy a booster pack for emergencies and plan to replace the battery more often. Or drive the car more! Oh well, I used to be in a highrise condo and rarely drove my car, but being a car guy I had to own a car and so it was never a match...I moved.
I would actually suggest a solar panel that connect directly to the 12-volt cigarette socket. Unless its in a garage of cause. There are some smaller foldable panels you can place on top of the dash. I know it sounds crazy but I get your point - you don't want to disconnect the battery but still would like some maintenance charging.
When I park longer than two weeks indoors with no access to power, I'll disconnect the negative side of the battery and leave the hood slightly open. Somebody in a post here on Rennlist suggested that leaving a town in the latch to ensure nobody shuts it on you. If they happen to do that... I have no idea if you can power the car through the cigarette lighter to pop the hood.
