Fabspeed NEW Competition Air Intake System with Two Filters
Installed Fabspeed's New Carbon fiber Double filter CAI this weekend. Good deal from Undergound Tuning. Fairly straight install, except for a few observations: Car is a 08 997 Carrera 3.6L
No instructions in the box. (Not cool) I used the You tube Video as a guide from the previous model.
The heat shield mounting rubber grommets designed to fit in the engine bay deck holes are too WIDE. I had to shave the rubber down with a dremel, in order to get them to fit in the holes. easy to do just reduce and test. reduce some more...
The black 6mm hex bolt used for the heat shield brace is too long to tighten in the existing hole on the motor. I had to use the 2 rubber washers,(included) and 2 pieces of 3M double sided tape underneath the bracket to get the bolt to tighten down.
This kit has an extended heat shield that hast to be mounted in the engine bay after the main heat shield is in place. Nice added touch but hard on the knuckles to tighten the 3 bolts and nuts.
The OEM Mass Air Flow sensor housing uses a security torx bit. FYI...
Once everything was installed, i went for a run. There was a very high pitched resonance at around 6500 RPM. I used rubber door seal tape and cut pieces to fit on the heat shield at each top corner left and right and underneath the oil filler tube that clips on the steel bracket. The tube has a small "foot" sticking out of it right where the tube meets the heat shield and was rubbing. Resonance squeal solved!
Impressions.
Wow! The sound of this intake was impressive! You would not know it was installed until you spool up to 4k RPM. Between 4-5k, there is a nice almost turbo sound starting, at FT over 5K, the car sounds amazing, an aggressive GT type wail, or howl but never annoying or too loud. I love it. It sounds like the car looks if you know what I mean.
Butt Dyno tells me there is absolutely more torque from 2nd gear on. She is quicker has quicker throttle response and pulls much stronger now. 4 different people have said something regarding acceleration while in the passenger seat. In first gear I am not feeling or hearing to much of a difference…
And of course the eye candy factor looks freakin awesome back there: I am very happy with the purchase.
Impressions.
It looks so sick though...
Looks great. Butt dyno?? Really?
No offense but I need help understanding a few claims
It pulls stronger? Pls explain
More torque after second gear? Wow, you can really feel the difference? It can't be much more than 5-10 ft lbs right? Is that really noticeable? And to feel it after second gear...
Does the intake really effect throttle response? I wouldn't have guessed that
Thanks for helping a newbie understand
Why would you say that? Do you have any experience dyno testing 996/997 cars?
I will make some comments later in this thread, right now Todd from Evolution Motorsports is here and we are doing some custom Ferrari tuning.
Let me guess, you dyno with the lid open and a huge fan blowing on the engine?
2nd to 5th in my car are where I can feel the most power, the 3.6l can be sluggish, now I feel it Is more responsive and less gas pedal is needed to get up to speed.
The K&N Air Intake is about $350, how much is the Fabspeed option?
http://www.knfilters.ca/search/produ...x?Prod=63-7001
There is, I had one, part # 57-7000. Although, one bracket needs to be bent as it does not fit correctly. However, I would not recommend it for performance, as it doesn't do anything as far as I could tell. When I returned to stock, my butt dyno said there was an improvement, but that could have been psychological. It does improve the sound nicely though.
I actually tried a run or 2 with the engine lid open, and the car did not pick up power.
Below is my chart on a 3.6 996 C4S. If you look at the air/fuel log you see the K&N runs over 1.5 points richer....way too rich for this car. At that specific rpm, the car lost 14 ft. lbs of torque to the wheels.
