Carrera GTS Autocross
It was my first time with the car in a controlled environment. I wanted to go faster but me and my instructor had systematically different ways of learning the track (he drives a 964) so I was holding back quite a bit trying not to push him above his comfort level.
I guess I eventually scared him out of the car, so on the last lap I tried getting into hoon mode, but PSM was on and wasn't having any of it. The car was in Sport+ but I was surprised to find how little if any throttle steer it allowed during slip. I also found the PDK buttons to be cumbersome, I kept upshifting with my palms on accident.
Overall good day and hats off to my instructor for staying with me until the last run.
https://vimeo.com/83506617
They were 10mm new. I measured 6mm on the rears and 7mm on the fronts a couple of months ago. I would say they the rears currently have 30-35% of the grip when compared to new, and the fronts with about 45% grip when compared to new.
So not the best grip anymore, but they still have good tread, feel, and remain predictable at the limit.
I've never understood the appeal of autocross - especially with it's lack of actual speed. Maybe I should give it a try. Is the 911 supposed to be a good autocross car?
DMoore
'13 C2S (with paddles)
'13 Panamera GTS (with multifunction buttons)
You may not carry the sort of raw speeds you do at an HPDE, but you're still moving at highway speeds, and you're operating much closer to the edge of traction, and doing so for much more of the course. I find autocross incredibly addicting. It's low-cost and low-risk, you should give it a shot
Isn't that all Carrera GTS come with paddle shift as standard? Did you order yours with Multifunction steering?
While I mainly stick to the track now days auto-x is a great environment to learn car control, reaction time/hand eye coordination and improve your ability to learn a track quickly. If you have an instructor who is not comfortable with speed, they need to request a different instructor or go it alone. You need to push to find your and the cars limits. Typically when you start to hear the tires you are on or at the limit of grip. Also be aware of surface changes and imperfections.
When you walk the coarse, walk the your driving line as if you are in the driver seat and look ahead. You may also need to over inflate your tires to prevent them from rolling over. Be sure to monitor, record, bleed and tune your tire pressures in between runs. You don't want the tires to roll over past the tread blocks.
Cool video I came across, some slow-motion shots:
