Adding a turbo to a 997 ?
Hey there , I was looking for some advice on increasing hp to my base 05 c2 .I was thinking of adding a turbo ? I have already added a exhaust bypass , chip , IPD intake plenum and a GT3 throttle body . BUT it still is not fast enough . Suggestions would be greatly appreciated . thx
I think the cost involved making a NA Porsche turbocharged would prove to be not worth it. As a matter of fact,I believe it would be cheaper to just buy a Turbo car.
+1 plus its always harder to sell a modded car. If you do install a "Turbo" to your 05 c2 it still would not be as quick as a 997 911 Turbo.
Thx , guess I will just have to save up for the real thing . Being a new Porsche owner I was told the maintenance costs were high but I will have to settle on this for a while .I have owned it for two years and you still can't punch the smile off my face every time I get into it . Come on spring time
I've always wondered about how wise it is to turn a normally aspirated engine into a turbo - because mechanical aspects of a car don't happen in a vacuum, or independent of other things. That is, you turbocharge your car and you obviously up the HP/torque. But now your 3.6L engine (using a 2005 C2 as an example) drive train is handling stresses that it was not designed for and this can't be a good thing for a car that is already eight or nine years old. But say everything with your engine is fine, and stays fine. Your car is now able to go a lot faster - but it's brakes and suspension were not built to handle this speed. I suspect you could modify many of the attendant components that go along with maximizing the effects of turbo power, but it would not be cheap - at the end of the day, you'd probably have been able to get an actual used turbo for what you end up paying to turn a C2 into one.
You mentioned in the IMS failure poll that your IMS failed (which usually means engine-go-BOOM), but mention here that you replaced the IMS, costing ~$1300. Were you able to somehow save the engine? Tell us the story!
Yep.
997 turbos can be had in the low to mid sixties with a little more mileage on them (40-50K). Better to go the route of the proven Mezger engine if you want a turbo.. I was amazed at the difference between my old 997.1 C2S and the 997.1 turbo..the torque down low is a huge difference..
And if you are into it, the turbo is much easier to mod to get more power out of.. (note I said easier, not cheaper )
I bought a NA C2S because it fit in my budget at the time. When I can justify spending the extra 20k I will sell my C2S and buy a Turbo.
I think turning an already perfect car into a science project for a few hp is wrong. If you want to bolt a turbo on a Honda Cervix, I say all the power to you but it is blasphemous to be meddling with a Porsche.
