Water in the trunk
Water in the trunk
I've noticed that my front trunk hasn't been completely dry. My car was at the dealer the other day, and I had them check it out. Supposedly they cleaned out the drains and checked the rubber gaskets, and found everything to be OK. Although I'm not sure exactly where the drains are, but the rubber looks OK to me too.
We just had a couple of days of heavy rains, and it looks like whatever they did, didn't do the job. See photos below.
Is it possible that they missed some drains? Other than the drains and the rubber, is there anything else to look for?
Happens with me when I wash the car but not too much when driving in the rain. I guess if the car is parked outside in the rain, it's almost like the car is being hosed down. When I wash the car, I put a towel over the battery area just as a precaution but I always have to wipe down around the rubber piping in the frunk.
PS: The pic links are broken.
The pic links seem to be working for me. Is anyone else having trouble seeing the photos?
Mine has never had a drop get through the seals. Mine is outside often and washed often and nothing like that has happened. Something is wrong.
+1... would you post a few pics of the seals and plastic molded pieces surrounding the area within your interior frunk. We can compare it to what we have JIC something is missing and/or installed incorrectly.
There are drains in the battery compartment that can become blocked with debris. Periodic cleaning is needed. Not quite sure where they are located. The trunk can become a fish tank. Don't ask how I know this.
There are also drains in the rear on the cabrios that can get blocked and retain leakage into the rear of the car. Neither of these issues are very well published. There are threads on this forum that address them.
@ Fahrer - Man, you've got good eyes! After checking it out, I noticed it was slightly out, so I pressed it all the way in. I would say it's very unlikely that it would've been responsible for allowing that much water into the trunk, but I guess it's possible. We shall see. Thanks very much.
@ MichaelL - You're absolutely correct about the importance of cleaning the drains on a regular basis. In fact the previous owner had neglected to do that, and a few months after buying my car I found out the hard way. After a heavy rainstorm I found about an inch of water in the driver's side footwell, which fried a control unit under the driver's seat. The whole experience cost me close to $1500, because in addition to a new control unit, they had to take the seat and all the carpets out to let everything dry. I've since had all the drains cleaned, including the drains by the battery....or so they tell me. I'm going to have them double check that when I take my car back to the P dealer on Thursday.
Poseur
Another entry point can be via the small gaskets that separate the trunk area from the headlight buckets. Make sure they are intact.
The trunk should normally be completely dry. Something is seriously wrong. To troubleshoot this issue you can always use silver duct tape in certain areas to discount them as contributors.
Has the vehicle ever been in a frontal accident (even ever so slight?)
Have you checked for the frunk side carpeting for dampness? If leaking past the gaskets the water should be following the sides on its way to the floor. This may give a lead on the origin.
The plastic molded pieces surrounding the area within your interior frunk looks OK. Is your car parked on level ground when this occurs. Would it be possible to get a pick of the underside of your frunk hood? Until we figure this out it might be good to use a car cover even in rainy weather to keep most of the water out.
