Vandalised 997
Vandalised 997
So I made the mistake of thinking I could park on the side of the road without having my car destroyed.
Some nice guy decided to go to town on my 911, and now I'm in a very rough spot.
The bastards keyed it all the way down to the metal as well as thrashing all 4 of my rims. They also kicked in the rear panel.
My insurance recommended a shop that they deal with, so I'm getting a quote from them.
The whole car needs to get repainted, and 4 new rims need to be ordered at $1900 a piece.
They are going to take off all the panels and sand them down for repainting. Should I get them chemically dipped instead?
They aren't even using oem paint, they are using a "high quality european paint" matched to guards red, but I'm worried about resale value.
Any one have any tips or suggestions?
I'm totally F*%$^* here, my deductible is 2500 dollars and I'm sure they'll be charging me more....
Unless you have a very unique policy, you choose the shop and the shop negotiates with the insurance company. With that said, search for a shop that deals with high end cars and, in particular, Porsches.
With computer aids helping the paint mixing and blending, a good shop will do a great job.
I would insist on oem paint. I'm sure you know it water based.
Plus I would want to know regardless of a complete body spray or not that they have the ability to
properly color match it.
Most if not all the Porsche dealers have their own paint & body shops.
I used Phaff Autoworks when I had my ducktail installed this spring.
I was a bit worried as the paint was 8 years old but they matched my 2005 Speed Yellow perfectly.
So sorry to hear about this brother. You wouldn't think this sort of thing would happen in Nova Scotia, but I guess there are jealous a$$holes everywhere.
Just think, you could've been in a bad accident or something else. You're OK, and your Porsche will be too. Just make sure you really do your research on the body shop. The great ones do a fantastic job.
Sanding is ok. Not sure what chemically dipping the panels buys. Might be ok for a barn find with corrosion or with many coats of paint.
Body/paint shop should use one of the Porsche paint systems. From memory: Spandox, Spies-Hecker, or Glasurit. If it doesn't run do not walk away.
Guards red is not a hard paint to match if the shop knows its stuff.
If you want to be picky insist the paint thickness be made to match the factory paint thickness. The paint thickness varies from say the top of the fender to the bottom as the placement of the panel in the paint booth means some portion of the panel gets more paint spray. A good Porsche shop should know the paint thickness characteristics and sand to match so a paint thickness meter can't tell the difference.
'course, the absence of factory orange peel finish will let a pro know the car's been painted...
Be sure you observe the shop pull and tie back the rubber so the paint goes on smoothly with no ridge from paint tape. These ridges are a sign of a subpar paint job.
Also, feel the finish of the painted surfaces not directly visible. This includes the panel edges and the surfaces under the edges of the panel. These can be left rough from overspray. Check out a new car and get a feel for what the surfaces should feel like.
Be sure all stickers that are present on the car before any repairs are carefully removed, saved, and restored afterwards. Take pics. Lot of pics.
That's awful news, I can't believe people would go out of their way to do that to a car. What part of NS did this happen? I'm from the valley area originally... can't imagine an east coaster would do that without being seriously messed up in the head.
Pick the shop you are comfortable with and tell them your concerns about non-OEM paint and see what they say.
Shocking someone would damage a car so extensively to require a full repaint as well as 4 new wheels. Bastards will always get their due.
Don't know about "most if not all" but some do and it means......not much sometimes. My dealer has "it's own" remote paint & body shop but the only reason they call it their own is that the owner of the Porsche dealership also owns the body shop which is actually affiliated with a Cadillac dealership he also owns. I had the misfortune of learning first hand just how much this body shop's work sucks. Do your own diligence no matter what the dealer recommends.
