Rev limiter question
My new-to-me 997.2 had logged zero over-revs when it was PPId before I bought it 5 weeks ago. I bounced off the rev limiter in 1st gear today (MT). It cut the fuel just before (~<0.5 s) the clutch was depressed for the up shift. Is this a range 1 or range 2 over-rev?
IIRC, the ranges are in 500rpm increments. I want to guess the limiter would keep it within range 1. Were you in sport/sport plus mode? I believe that is more lenient in cut off which might allow further up redline, but I think still within R1. This are from my own observations.
I could be wrong but I believe that Range 1 is just below the limiter, Range 2 is bumping the limiter and it's possible to get into Range 3 by slamming the limiter.
997.2 Over rev ranges:
Range 1: 7300-7500 RPM
Range 2: 7500-7700 RPM
Range 3: 7700-7900 RPM
Range 4: 7900-8400 RPM
Range 5: 8400-9500 RPM
Range 6: 9500-11000 RPM
Classification of over rev ranges:
RANGE 1 Maximum engine speed exceeded; engine damage very unlikely.
RANGE 2 Maximum engine speed exceeded; engine damage unlikely.
RANGE 3 Maximum engine speed exceeded; engine damage possible.
RANGE 4 Maximum engine speed clearly exceeded; engine damage probable.
RANGE 5 Maximum engine speed very clearly exceeded; engine damage very probable.
RANGE 6 Engine damage has generally occurred.
Overspeed events are stored in the DME control unit.
The following values are also recorded:
1) Number of ignition attempts in each overspeed range
2) Status of the hour meter during the last overspeed event
Thanks all. Based on your responses, I suspect it was range 1 with a possibility of range 2. Even if it was range 2, at 0.5 s, it would be less than 200 ignitions . I see a Durametric tool in my future.
Received 5,388 Likes
U r fine. A few Range #1 and maybe some Range #2's. Just don't make a habit out of it. Don't do this on a down shift.
It's probably a little scary the first time it happens and you worry that you "hurt" your engine. Really though, if you over-rev on the up-shift and the limiter kicks in, it's doing what it is meant to and protecting your engine. Of course, it is probably a bad idea to do it on a regular basis.
I wouldn't be surprised if a new DME report still shows zero range 1 over revs. Do you have access to a Durametric? It'll show the over revs.
I didn't think bouncing off the limiter on an "upshift' stored a result in the DME.
