About to buy tires, should I go Bridestone or Michelin
To the OP, based on resounding reviews of others on the forum and my own SA's recommendations I went with the MPSS for DD, longevity of wear, and lower cost. I'm still keeping my near new PZeros on my factory Carrera Classic wheels for DE's... they're better for track use but noisier for DD and wear out quicker. They're also N-rated which may help if/when I resell the car. Note that P-dealers can only CPO a car with N-rated tires. Perhaps something to consider should you need to trade-in the car in the near future. Of course, if the tires are too worn then they'll need to be replaced regardless... so use until resell may be a factor to consider when selecting a non-R rated tires such as the MPSS over the Bridgestone RE's.
Or it's the difference in torque values from one bolt to the next. But why even risk any issues for a $30 delta in cost... is that really worth it? If you must use Costco then at least re-torque your wheel bolts to 96 ft-lbs when you get home in an alternating pattern.
Hankooks are much quieter!
It isn't the "over torque" as much as it is the uneven torque. Way back in the 70's I had a couple of cars experience warped rotors after trips to dealer and tire shops. Since that time whenever any of my cars go in for any kind of service where the wheels come off I retorque the wheels myself within a day after the car comes home. I've never experienced a warped rotor since. I often find significant difference between left side wheels and right side wheels too.
Looks like the Michelin Pilot Super Sports seem to be getting a big thumbs up from everyone... but what about them not being "N" rated? Does that matter?
...Way back in the 70's I had a couple of cars experience warped rotors after trips to dealer and tire shops. Since that time whenever any of my cars go in for any kind of service where the wheels come off I retorque the wheels myself within a day after the car comes home. I've never experienced a warped rotor since. I often find significant difference between left side wheels and right side wheels too.
I just want the job done right the first time. No more warped rotors from uneven or over torque, No more snapped nuts/bolts, no more on the side of the road with a flat and I can't muscle the nut/bolt off without a breaker bar. I have already reconciled with myself that when it comes time for tires and TPMS, I'll call the dealer, have them order in from tire rack and bring the car by to them. I've already priced it all locally and there are within $100-140 difference all totaled. Worth it and if I've got one of my dealers 10% coupons then it's even less of a delta.
Good luck!
I have not had Brodgestones but Hella-Buggin says he had the Bridgestones and he didnt like them as much as the Michelins.
I have had multiple sets of Michelins and while the PS2' are competent, I find the Pilot Super Sports to be a better overall tire IMHO. I have them on both my Panamera and my 997.2. It doesn't hurt that they are also cheaper than the PS2's. The ride is quite comfortable and smooth compared to the PS2's.
You can get a great deal from Discount tire Co. or Tirerack and have then shipped to your dealer for install if you cant find a local shop that has the expertise to not scuff, scratch or find some other to ruin the unmounting and mounting experience.
Think about it!
Think about it!
Just to point out the difference in durability between the RE050A and the super sports, I adverage e about 12k miles out of a set of rears with the bridgestones. I currently have about 9k miles and 5 tracks days on my super sports with plenty of tread left. Now, I'm in the beginner group so your de tire wear may vary. I also rennet the bridgestones being very loud towards the end of their life and quite jolting over bumps.
I have had both. Unfortunately my C2 came with new Bridgestone RE050As, so I am stuck with them for a while. After only about 2000 miles they are already getting noisy when cornering. When the rears are worn, the fronts go, too. I can't wait to get back on Michelins.
Costco offers the Michelin Pilot Super Sports in 235/30/19, but I don't see them for the rear size (305/30/19)... hmmm gotta call them.
Is there any advantage to filling your tires in Nitrogen? Or is all of that just hype?
Tire balancing equipment used by some tire installers. Not necessarily an indicator that the tire installer knows how to work with our cars but the Force Balancer is one of the better balancers out there on the market. For example, the local Firestone in my neighborhood has a Road Force Balancer but they know very little about how to mount our cars nor how much torque to use... let alone what size/type tires are used on our cars.
