Lets see your 997...
Old 12-16-2018, 01:49 AM
  #3766
sandwedge
sandwedge's Avatar
Received 1,006 Likes on 714 Posts
Originally Posted by ocgarza
OK, OK, it is not a 997. But have you ever tried to find a Hot Wheels 997.2 C4S?
Not exact in every detail but probably meant to be based on a Magnus Walker build he brought to Jay Leno for a ride. Originally a 1971 911T. Here's the video and the car.
Old 12-16-2018, 02:30 AM
  #3767
Vincent713
Vincent713's Avatar
Originally Posted by Petza914
Yes, but I'm not sure that's the best idea. If using a pressure fed beating, yiu don't need the ball bearing - it will just ride on the oil film. Fewer moving parts and lower risk of failure and metal debris in the motor. I think it's offered by Vertex auto or ECS.
Yes I agree using the non (ball) bearing is the way to go but wouldn't this oil feed system be easier to install and cost less?
Old 12-16-2018, 11:35 AM
  #3768
ocgarza
ocgarza's Avatar
Originally Posted by sandwedge
Not exact in every detail but probably meant to be based on a Magnus Walker build he brought to Jay Leno for a ride. Originally a 1971 911T. Here's the video and the car. https://www.youtube.com/watch?v=VB3JZlV6RDM
Wow. I wondered what the original might be. Saw it on the Hot Wheels display in WalMart a few days ago and picked it up. Thanks.
Old 12-16-2018, 12:47 PM
  #3769
///Malcontent
///Malcontent's Avatar
Originally Posted by amplitude
9A1 is sans IMS, yes?
Correct. The 9A1, which was introduced in the 997.2, has no intermediate shaft. The cams and oil pump are driven off the crankshaft.
The pic at the link below is for the 9A1 in the 991.1 GT3, but the architecture is the same.
https://rennlist.com/forums/attachme...h-bullitin.png
Old 12-16-2018, 02:13 PM
  #3770
Petza914
Petza914's Avatar
Received 6,128 Likes on 3,903 Posts
I personally think you're better off just pulling the grass seal and letting the bearing sit in the sump oil which will provide plenty of lubrication. Pressuring an oil feel line to it might cannibalize your oil pressure to the engine when you need it most, creates a point of failure on the oiling system for the engine that isn't there today, and a ball bearing isn't designed to have a pressurized oil feed which could create internal bearing resistance increasing pressure on the timing chains. Regular bearings need it because they just ride on the oil film, but ball bearings or roller bearings don't.
Old 12-16-2018, 02:26 PM
  #3771
SonicJLee
SonicJLee's Avatar
Just picked up my first 997 on Friday. I appreciate all the help I recieved on this forum during the shopping process. I had a 991 C2S before this - I always preferred the 997 look and feel. I'm happy with the switch.
Old 12-16-2018, 04:34 PM
  #3772
bweSteve
bweSteve's Avatar
Received 1,036 Likes on 657 Posts
Originally Posted by rudycob1
Re: 2 pics above of your car .. what looks to be a RSR Tribute. Can you give more info on what you are showing here? Is that a temporary set of rims/tires? ..
or maybe the lift is pushing up on the car for some work you were doing?
.... looks a little out of place in that Ferrari garage. ... and my eyes are playing tricks on me with that wooden floor
Old 12-16-2018, 06:54 PM
  #3773
rudycob1
2nd Gear
rudycob1's Avatar
This started life as a C2S. Full RSR body conversion with a few extra modifications. Wheels are correct split rims made to order to keep gearbox ratios and clearances.
If wheels were bigger they will hit the body on suspension travel and full steering lock on front. RSR has very different suspension configuration. Picture is a little obscure due to angle. Still playing with suspension set up. Might need 15mm rear spacers (max) and lowering about 1". RSR body has higher wheel arches than standard arches. Body is an original race car body from Albert Motorsport in Germany and has been a lot of work to get it to look good on a road car.
Garage - Ferrari, there is a reason. There is one in my other garage but this has the ramp so easy to work in.
Like you pointed out this is a tribute or take on an RSR not an RSR. Something a little different.
Old 12-16-2018, 10:17 PM
  #3774
Vincent713
Vincent713's Avatar
Thumbs up
That makes a lot of sense, thank you for shedding more lights on this matter and for your feedback. Really appreciate it.
Old 12-16-2018, 11:04 PM
  #3775
Arctic997
Arctic997's Avatar
Default Hate cabs? You haven't driven one.
Almost nothing beats a warm summer night and a dropped top.
Old 12-16-2018, 11:24 PM
  #3776
Terp20854
Terp20854's Avatar
I've never needed a like button more. Good lookin cab there.
Old 12-16-2018, 11:46 PM
  #3777
Arctic997
Arctic997's Avatar
Thank you.
Old 12-17-2018, 04:35 AM
  #3778
Byron CA
2nd Gear
Byron CA's Avatar
Default 997
Originally Posted by switch911
Mine:
Mine
Old 12-17-2018, 08:40 AM
  #3779
D1coach
D1coach's Avatar
Beautiful color, great find. I also returned to a 997 after owning a 991 for a time.
Old 12-21-2018, 10:14 AM
  #3780
qikqbn
qikqbn's Avatar
LOL, yes it would, but that only works for 2 and I have a whole theme going.
1st one
Next one
Wife's
Supercharged 928
Widebody Turbo S Cayenne
That's a sweeeeeeeeeeet garage / stable you have Petza914. Neighbors must think there is a Porsche dealer near by. Your driveway is a bit hidden from the main road, but if I had all my toys out my wife would say " go put your Porsche's back in your pants, your making the neighbors jealous"
Quick Reply: Lets see your 997...
