Can we just clean our engines using a pressure washer? What are the donts?
I rarely wash mine but when I do I spray it with Simple Green, let it soak about 10 min then rinse off on low pressure. Avoid any electrical connections.
Works great, inexpensive.
I believe this technique will be the method most used going forward:
http://www.pedrosgarage.com/Site_5/F...ad_Grime!.html
He's asking a valid question. Under-hood electrical connectors on American cars are waterproof...on German cars, they're generally not. He may have been doing this for a long time without incident...
Indeed...
I've never been an engine. What's it like?
Indeed...
The Best and Safest way to wash your engine is to use P21s Total Auto Wash http://www.detailedimage.com/P21S-M1...000-ml-Kit-S1/
Spray it on, use brushes to get the tight spots then hose off using no pressure.
This product is safe for aluminum, hoses, plastic, belts and wire harnesses
It seems there are some who clean some who do not clean their engines. The article shared by sullivas is unique, never heard of this technique but the pictures do impress, i have to get more info.
To those who do not clean, so many here share their detailing escapades, hiw they would clean all the nooks and cranny and spend the whole day doing the job. After which they would grab a beer and enjoy the fruit of their labor. The engine and engine bay, imho, should not be left off. I have cleaned it and the result made me smile. The connectors on the porsche look like they are sufficiently protected from water and after washing, the girl simply started up without much fuss. Pressure washer might not be a good idea as some suggested, and since pressure from tap is sufficient, maybe best to just use that.
"Tough crowd", i agree. I can only say to that for people who have not experieced something or have not done it, its not reality and may sound ridiculous. For other who have, it is reality and it becomes an ordinary matter. I think this applies for all situations, not only engine washing.
I try not to repeat things that I "hear". I state things that I know. I've pressure washed the under-hood area on every American car that I've ever owned and never had a problem because their connectors are sealed. I've also owned several later-model VWs and Mercedes, and have been warned by all their associated dealers and owner's manuals not to wash under their hoods...for fear of electrical failures. And, after examining the German connectors, I can understand why: they're not sealed very well, if at all. So, I let them get grungy and take the ensuing flack from my friends...
There are several uses of best pressure washer.
When it comes to me, i use pressure washer for car wash, floor wash.
As others have mentioned, cleaning an engine is often part of a full detail and I have always done it. A clean engine makes it easy to find leaks, keeps fasteners in tip top shape and avoids that caked on crud when you need to remove a component.
Citrus based cleaners are a good idea, I also use steam for really tough sections with a detail brush attached. I've been doing this for 20+ years and never had a problem. Obviously you need to be extremely careful anywhere air is meant to go (keep it blocked off) and also as others mentioned, the electrical connections.
You can use a pressure washer on some parts of an engine but generally speaking, it's a bad idea. It doesn't take much force to work water into electrical connections and into nooks and crannies where it doesn't belong. Plus, it makes an awful mess. There are so many angles, edges and curves in the engine compartment that you'll just wind up splattering filthy water all over the engine compartment, the exterior of the car and yourself.
A mild cleaner or a degreaser for oily residue, sprayed on and agitated lightly with a brush, then washed off with low-pressure hose water is usually sufficient. Be sure to keep the water away from any possible entry points into the intake.
Mark
