Looking for 997.1 turbo wheels in narrow body fitment, are these real?
Does anyone know if the 997.1 turbo wheels come in narrow body fitments? IE 8x19 ET57 and 11x19 ET67? I've been looking but can't seem to run across any.
I'm not sure of the specs, but here's a set of turbo wheels on a C2S - I think they look great: http://images.autotrader.com/scaler/..._A.562x421.jpg
Chris,
I also have an atlas/black and absolutely love your car. Did you paint the lower lip to match or still black.
Can you get me specs on your drop etc. Thanks and sorry for the derail
Pm if you want.
Caesar
Pm if you want.
Caesar
Poseur
After Porsche AG introduced the 997 Turbo with the Turbo wheels (forged, and made for Porsche by Otto Fuchs) they were soon made available for the non-AWD narrow body cars. Not being a cast wheel, the dimensions (width in inches and offset in mm) are not seen on the outside area of the wheel. If you look inside the back side of these wheels you will see that they are legitimate Porsche wheels provided the Porsche vendor logo is on them--and they will show something other than the turbo (wide) body offset.
C2S
Front: 8 J x 19 ET 57 Front: 235/35 ZR 19
Rear: 11 J x 19 ET 67 Rear: 295/30 ZR 19
C4S
Rear: 11 J x 19 ET 51 Rear: 305/30 ZR 19
Turbo
Front: 8.5 J x 19 ET 56 Front: 235/35 ZR 19
So is it safe to assume a NB car could take the C4S or Turbo fitments without spacers (on rears) since many of us run 7mm front and 15mm rear spacers anyways?
for what it's worth, here's a picture of the difference between the C2S (19x11.5 +67, Green) and Turbo (19x11 +51,red) rear wheels. they only stick out a wee bit more.
I run WB Turbo rims on my NB C2S. The rears are exactly flush with the fender, however if you run a 305 with wide shoulders or a thick protective lip (ala Michelin Pilot Super Sport), the tire will protrude from the top of the fender, however I have never had it rub. It only looks a bit odd from particular angles imo. The fronts fit fine, in fact I still run 5mm spacers on the front wheels which push them nearly flush, which makes them better match the fitment of the rear. Again, no rubbing.
Another factor is that the WB Turbo rims have a more dynamic looking "dish". The offset of the face looks more aggressive than the NB fitment.
