I just removed my TS mounts and went back to OEM. I liked the feel of the car on the track but for normal everyday driving it was not ideal. Keep in mind I also have the Function first trans mount insert. Good thing is they are easy to install
Did you find the engine mounts amplified the noise you're getting from the FF trans inserts on their own - many I've talked to said they don't multiply each other?? Thanks,
I would not say they amplify each other but I can tell the FF mount is there. It is minor but its there.
