What's your Mileage?? 997.1 & 997.2
#316
2009 at 38K miles, only drive on weekends as I take subway to work. Next biggie is the 40K service which I predict will be needed by December. I'll also do new coil packs and coolant reservoir at same time. Mods are FVD tune, BMC air filters, and Fabspeed X pipe. And Numeric shifter, I have the cables too but not installed yet. Maybe I'll get that done too at the 40K service.
#317
Sir Thomas Lord of All Mets Fans
Originally Posted by SoCal C2S
Just about to hit 60k miles. Only scheduled maintenance and some preventative....water pump, coolant tank, coils, motor mounts. Then the miriad of mods.
T
#318
117k 2007 997.1S with 6 speed manual. Original clutch. New motor by Porsche around 80k. No issues besides the water pump. Taking it on a 4K trip this weekend!
#320
Bought my 2011 C2S just about 2 years ago with just under 16,000 miles on it -- about 17,500 by the time I got it home. It's got just under 36,000 miles now. I feel a little bad about turning it from low miles to medium miles but forget about it every time I climb into the cockpit. ;-)
#321
Not sure what you meant or referred to when saying no issues besides waterpump but to me replacing an engine at 80k miles is a big issue for me
#322
60K is the PDK oil ...
#323
I am not sure why people own this car if they will not be driving it...so sad
#324
The 9A1 on the .2 cars doesn't seem to have reservoir problems.
#325
Was previous owner so I guess I don't really think that much of it. I have the full receipt, think it was bore scoring from what I can gather. Posted more to say that the car has held up very well at 117k in regards to everything else.
#329
My current mileage (2009 base Carrera) is a bit over 23 mpg. I have noticed that the indicated mileage is about 1.1 mpg higher than my actual mileage (the number was about 0.5 mpg for my 996).
I had to go to Long Beach, CA yesterday. The drive through Camp Pendleton is relatively flat, so I thought I'd set the cruise control at various speeds and see what the indicated mileages were. This is the raw data that showed on the computer:
57 mph 33.8 mpg
62 mph 32.6 mpg
67 mph 31.8 mpg
70 mph 30.3 mpg
72 mph 29.2 mpg
I'd guess the mpg numbers were ±0.2 mpg. Performing a linear regression (and adjusting for the 1.112 mpg error and the fact that my odometer reads 2 mph higher than the actual speed) I got the following relationship (please note that this is valid only between 55 and 70 mph):
Actual Mileage = 48.9 - 0.29 Actual speed.
Note that the mileage was departing from linearity above 65 mph (not too surprising since drag is an non-linear effect).
To be more accurate, I should repeat this on I-8 in the desert east of San Diego where there are flat sections that run for tens of miles. Other factors are tire pressures (mine were about 1 psi low), ambient temperatures, etc. I'd also run higher and lower speeds to see how linear the relationship is.
57 mph 33.8 mpg
62 mph 32.6 mpg
67 mph 31.8 mpg
70 mph 30.3 mpg
72 mph 29.2 mpg
