Steering wheel sizes???
Hi all, newbie with 997 cs, love my new car to bits but one little thing bugs me, being 6'3" I find it a little hard to find the perfect driving position , tryred most things seat adjust and steering wheel adjust full up, but still find steering wheel on my knees when changing gear, also uncomfortable , the only answer I can think off is a smaller steering wheel. Is there such a thing from a different model does anyone know?or a flatt bottom wheel would help, any ideas?. Are all 997 wheels the same size? What size are they? 320?? Or anything after market ???
Many thanks Pete.
Many thanks Pete.
Many thanks Pete.
Many thanks Pete.
To answer your original question, I don't know if different size steering wheels are available. My car has the sport steering wheel (round airbag). I believe there are aftermarket wheels.
I'm 6'3" as well (34" inseam) and 245 lbs, and have been able to find a comfortable position. That said, I prefer the seat back a bit more upright than many other people I know.
This is the adjustment procedure I use, which worked in both my 997 and my 993 before it (except the 993 didn't have an adjustable steering column):
Put the seat all the way back, and seat bottom all the way down front/back. Adjust the seat back to where the steering wheel hits your wrists when you stretch your arms out (alternatively or in conjunction, telescope the steering wheel). If needed, adjust the steering wheel up so you can see all of the tach (I frequently need to do this the first time in a car due to the seat back angle). Then raise the front of the seat bottom to where it's comfortable.
Hope this helps...
-Chris
Hope this helps...
-Chris
6'1 and the seat all the way back is too far. Tilt wheel up. Put seat down.
