How to remove climate control unit 997.1
Could someone tell me how to do this? I believe there are some hidden torx screws somewhere. Tried a few searches could not find detailed thread on it. Thanks.
Have you tried looking thru the PET catalog? http://www.porsche.com/usa/accessori...artscatalogue/ Just select your model and year range.
remove side bolsters, find the torx screws, pull out the unit and undo the wiring t the back. really easy... but if you are replacing it with at new unit, you need to program it with a piwis tester
You can find it cheaper at Suncoast: http://www.suncoastparts.com/product...997ELECTRONICS
Also, here's the post where I detail how I removed mine. I chose to refinish the switches rather than replace the module; $80 vs. $550.
https://rennlist.com/forums/997-foru...-switches.html
Jason
Jason
Because the switch is now hard plastic, not the tacky almost rubber coating it was on early models. It is that "coating" that peels, subsequently removing the TEMP and FAN logos. Porsche quietly made a change somewhere mid 997.1 production.
The other subtle update is the ECO switch now reads AC OFF. I'm not happy with the look of the refinished switches, so this was the only option for me.
I took the Air Conditioning Control Unit apart to paint the buttons. The wife wasn't happy with the finished product. I ordered a new control unit from Suncoast Porsche. I had the wife turn everything off on the control unit before replacement. I installed the new unit and everything works as normal. Dealer wanted $300 to install and they said it had to be calibrated?
Wife is happy so I'm happy. 2006 Cayman S wife's daily driver 67,000 miles.
Poseur
The hardest part is removing the side panels. See my write up and use the early section for guidance on that. The write up is about my Tooki installation. Do a search.
