PSE default setting on 997.2 on start-up
What's the default setting on PSE on 997.2 ?
On my old 996, it was on (loud setting) at startup, and I'm wondering if its the same on 997.2 Carrera with manual tranny, sport-Pasm, sport chrono. Being installed today at dealer. Thanks
The default setting for the PSE is silent.
If you want full control over your PSE exhaust without any speed dependant cut outs, you better check out our PSE remote control.
http://www.carnewal-europe.com/cpx_p97084.htm
Unplug the PSE connector in the engine compartment and your PSE will be ON all the time. The connector is on the RH side of the engine up along the intake plenum and runners. It's got a spring locking connector. Just squeeze the spring and you can disconnect the harness. Do a search, there must be a photo of this on this or other forums.
