What did you do to your 997 today?
#4771
#4773
Basic Sponsor
Thanks for the business! Wait till you hear those valves open for the first time at WOT with the X-Pipe
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
#4775
Started the process of adding a TT wing to my GTS per https://rennlist.com/forums/997-foru...a-carrera.html
#4778
Not in MA anymore
Attempted to remove the stock exhaust in order to fit the Sharkwerks x pipe I picked up, only to snap a few bolts and bloody a few knuckles. I'll attempt it properly by removing the bumper when it warms up this spring.
So instead, I just drove it.
#4781
Just had my short shifter and Sharkwerks x-pipe (and exhaust tips) installed.
If you drive a 6-speed 997 and you DON'T have the OEM short shift kit installed, you are doing it wrong. The driving experience is so much more improved with the shorter throws.
In terms of the Sharkwerks x-pipe, the sound is definitely improved. I knew not to expect anything crazy (based on the dozens of reviews and videos posted on all corners of the internet), but I am definitely pleased with the result.
#4783
Ditto
#4785
Installed BMC air filters today. Dropped a torx socket bit that went under the airbox and had to use a coat hanger to fish it out. Its a tight work space to get the airbox cover off. Not much room to get the screws out.
