Pls confirm how car should work on MAF disconnect
Could also be a bad O2 sensor on that bank (there are 2 per side). When I was chasing what turned out to be a bad ground to my MAF, the car would fall on its face if trying to give it any real throttle below about 2,500 RPM, but would pull fine at higher rpms at full throttle. There was no difference in this case with the MAF connected or disconnected but that makes sense because with no ground it was essentially disconnected all the time. I'm not sure if a failing MAF would behave differently, but think it probably would.
Frequently. Only when I start the car and let it warm up. If I step on the gas just a little, I can get around the possible misfire. I have a new MAF and that is not the problem. I am going to do coils and plugs soon.
Lastly if I am not in Sport mode, my car will also fall I its face when accelerating. Use Sport mode and no issue at all.
Thank goodness for Dynametric as it has saved me trips to get engine service off.
I have been having the misfire issue more
