View Poll Results: did YOUR car suffer an IMS failure
Voters: 1656. You may not vote on this poll
IMS failure for your 997 car, Y or N? tell us (yr, 997.1, .2, m96, m97, failure mode)
#226
Is there a documented failure of the late ims on late 2006 to 2008? I read an article in total 911 where well rept. UK company saying they have NEVER heard of a failure with the late IMS. Very interested to know. Thinking of getting a 997 4s. Im one of the 964 guys...
#227
what is the exact month where the revised, larger bearing was put into use? anyone know?
#228
I believe another thread identified a spring 2005 (Feb 05) manu date for the switchover for the 2005 3.8S models. Search for this thread - " Different! - 2005 S owners - what's your engine number and production date?"
#229
None has been reported. Article is correct!
#231
125K kilometres - no issues. It has the big nut = late IMS bearing.
Mine Is actually a 2002 996 with 195K kilometers *BUT* it had a factory reman engine installed at 70K kilometres in 2005.
I replaced the clutch two months ago and noted the big nut so could not upgrade to the LNE bearing.
The flange and RMS were bone dry. I didn't do anything to either of them.
#234
Why is the 997.2 even listed??? The IMS was eliminated!
#235
Wrong answer.
See post #217 on the previous page of this thread.
And that is not the only one that has been reported right here in this forum.
#236
Stil debating guys whether i should pursue purchasing a 2005 997 manual with less than 10,000 miles in the odometer ? Car appears well kept but the service records seems to be lost.
I'm a bit skeptical because of the possible IMS faitures. For now this is all what my budget would allow me to purchase. Ive also looked at a 2008 cayman s tiptronic but i would prefer manual tranny though.
Hoping to get some insights from this group. Thanks in advance.
#237
Pick up the 05' and update the IMS and RMS. This should run you around $1.5K. That's what I did and haven't looked back. Since my car has higher miles I also updated the clutch.
#238
Better still, drive it until the cllutch fails, or is about to fail, and do the work then.
You may be pleasantly surprised and find a M97 bearing setup anyway.
There's more difference between the carrera and the cayman than just the trans. They are different cars, with the carrera being more of one.
#239
Yes, definitely leaning towards the 05 C2. Had more fun driving that than the Cayman S. Thanks guys!!!!!
#240
IMS upgrades are available from LN engineering. I mentioned replacing the RMS since you may as well while you're in there. Updating the IMS only requires dropping the transmission and not the whole engine.
