Using the Sport Chrono/Sport display function.
Turns out I was wrong. You do have to hit the stalk twice. Select the interval option and push the stalk forward each time you want to start a new lap, then push again to confirm. Looks like you have about 5 seconds to confirm, so the second push isn't time critical. You'll see your lap information on the PCM, and you'll be able to review your times at the end of the session.
Reading the most recent info in the owners manual it seems you can set a lap to be a reference lap and record laps against it then download the info. I looks to already use GPS to track your lap. Not sure about auto lapping. Seems worth trying some random closed course to see what one can make it do and what the data is that it spits out.
That's what had me thinking about 'auto lapping' was the reference lap you can supposedly record/set and compare others against.
Still investigating.
The interface just SUCKS!
For timing:
One click of the stalk starts timing.
Two clicks stops the lap and starts another.
I don't know but I'm too busy driving...
Perhaps a beacon would be nice!
For timing:
Nope, it won't have anything recorded. You have to manually set the laps by pushing on the stalk. Once you've set the reference (first) lap, the sport display will show if you are on or off the pace (the circle is displayed in green or orange). It must track your distance travelled in some way or another.
We are not F1 drivers, I know, but with all the buttons and levers they have to adjust in corners and as they drive, is it that hard to operate one lever as you cross the start/finish line? Unless the spot you want to mark is at the entrance to a corner, it should not be that hard.. you do have to remember to do it though.
Yes, I've played with the start/stop/interval etc on the stalk but wasn't sure how to have it record a distance/lap and then time that lap repeatedly. (ie: lapping)
Surely you wouldn't have to activate the stalk every lap would you? I understood it was able to automatically record your laps each time you travel the recorded distance.
once to stop timing the current time period
once to initiate timing of the new time period.
flick, flick the stalk with your right hand's fingers as you cross the start / finish line or some other convenient landmark.
make sure you also study your PCM manual for user info.
it's worth figuring out so that you can compare the bar graphs later.
have fun
Craig
I too have heard of Harry's Lap timer, I'd use that next time out. The SC was a good idea badly executed. As for the "in dash" display present lap vs preselected lap, when oh when would you get a chance to view that pray tell? Down the Mulsanne?
*******philiac
In a DE event, too much with the double push (and you have to hold it for a beat, no?) and therefore inaccurate, I agree. But for a favorite section of road as the manual suggests, it's a fun distraction. I use it commuting. Traffic usually screws it up, but that's part of the fun, finding out if you beat the "reference lap". More of a curiosity/toy than track tool. IMHO, all the other features you get with the SC+ package are what you're buying. Haven't tried it on a T/D rally though. Could be fun. One thing it does do consistently: impresses first-time passengers.
I'm going to give it s go for the first time at an AutoX in a couple weeks, hopefully I'll be practiced enough to stop the clock and just not flash my high beams inexplicably at the timeslip provider.
actually, you have to do it twice at the end / beginning of each lap.
have fun
Craig
have fun
Craig
Okay so I think I got it pretty well figured out, and it's actually not too difficult!
-Go to the sport display screen and select 'start' trip'. This will be begin recording your trip as soon as you start the chrono.
-Start the chrono when you cross 'the line' which begins recording your first reference lap.
-Move the stalk as to highlight 'interval' but don't push it forward until you're crossing start/finish line.
-Push forward twice on the stalk rapidly. Which records your interval time (lap time) and also begins another lap.
-Once settled back in the pits (or your garage) select 'evaluation' from the sport display screen and there are all your lap times. Which I believe you can save the data as well.
I only played around with it out on a short drive and wrote the above from memory, but it seemed easy enough. Yes, if using it on a track you'll have to rapidly push the stalk forward twice each lap, but honestly it doesn't seem that bad to me. No, it won't be to the tenth accurate since you're responsible for stopping each lap and not a computer, but it's better than nothing I suppose.
I'm going to try it out this weekend properly and will let you know how it goes.
