No Sound :(
Old Feb 22, 2011 | 11:48 AM
Chimcu's Avatar
Chimcu
Default No Sound :(
Got into the car this morning, even before putting key into inition. I hear these noises coming from the Bose speakers... It sounds like static and then it stopped. I turn on the car and PCM, no audio what's so ever. Radio and CD ..
Anyknow what's wrong?
Old Feb 22, 2011 | 11:56 AM
997_rich's Avatar
997_rich
head unit showing radio stations etc?
if the head unit seems OK may be a blown fuse for the amp- i'd start by checking all of the fuses.
Old Feb 22, 2011 | 12:04 PM
Chimcu's Avatar
Chimcu
yeah head unit is OK.. hm.. I'll check the fuse later .. just thought it was kinda weird because all I did was press unlock to open the door..
Old Feb 22, 2011 | 02:52 PM
Chimcu's Avatar
Chimcu
All of a sudden it's working.. a buddy of mine told me it's static eletricity that caused it to not work this morning.. but not sure how it's working all of a sudden
Old Feb 22, 2011 | 03:03 PM
utkinpol's Avatar
utkinpol
mos likely it is your amp is dieing. mine died in pretty curious way - it started to do a very low frequency static discharges on all speakers. did it a bit, then for a month it was all fine, then it repeated and never went away.
i got it replaced by warranty.
Old Feb 22, 2011 | 03:25 PM
Skibum's Avatar
Skibum
Amp is dying... It will probably continue to do it intermittently.
I decided at the time to choose the exhaust note over fixing the amp. (2001 Boxster S)
Old Feb 22, 2011 | 03:33 PM
Chimcu's Avatar
Chimcu
hmm.. will a scan determine this? Now that it's working, if I bring the car in, how will they know that the amp is dying?
Old Feb 22, 2011 | 03:44 PM
Skibum's Avatar
Skibum
I highly suggest waiting until the problem is occurring.
If you can't bring it in at that time, I'd suggest a recording of what you hear... that should clue the tech guys in sufficiently.
Old Feb 22, 2011 | 04:42 PM
Chimcu's Avatar
Chimcu
wondering if AMPS are covered in CPO extended warranty
Old Feb 22, 2011 | 04:56 PM
utkinpol's Avatar
utkinpol
most likely not. electronics are covered by original warranty. your mileage may vary - tell your service manager problem started when car had original warranty and then was coming back and going away, may be something will work out.
if not - just buy damn thing yourself, replacement amp is somewhat $150 or so.
Old Feb 22, 2011 | 10:23 PM
cvazquez's Avatar
cvazquez
Get this issue on record with your dealership and work something out... I don't believe the CPO will cover the amp, so try the dealership first... Good luck!
