DIY On Porsche OEM Satellite Radio Install
Hello All,
A few months ago I completed my Porsche OEM Sirius Satellite Radio install in my 07' 997 C4S Cab. With Work and summer family vacations I put off writing my install up in a DIY and just got around to completing it. A big thank you to Ric at Suncoast for all of his help. As the doc it too larger (due to pictures) I have posted it for download (for free, just wait it out for a few seconds) at the following site: Download DIY Link: http://rapidshare.com/files/42279771...io_Install.pdf Regards, David |
Thanks for offering the link, but even with the "slow download" free link doesn't work. I'll try again, but can you confirm it's a functioning link?
Originally Posted by docfink
(Post 7944074)
If you continue to have issues, PM me with an email address to send you doc. Regards, David |
The download worked fine for me. Thanks for the excellent writeup. I'm curious what the Sirius tuner sells for. I have a GW500 installed in place of my CD changer (which I removed). Would this present a challenge to add the Sirius tuner now?
Originally Posted by keninirvine
(Post 7946094)
Thank you for the feedback on the doc, just giving back to the forum after all the vauleable info I have gathered here myself. Give a RIC a call at Suncost (no affiliation, just great service/support) and he can quote you on the two Porsche parts I listed in Doc, as that is all you should need from Porsche. All parts required are on first page of my doc. You shouldn't have any issue with having a GW500 w/out CD Changer, as you can see from my doc, my MOST loop setup is as follows: PCM -=>Tooki BT -=> GW500 w/ Changer -=>Sirius Tuner -=>Nav -=>Bose One disclaimer... The method I documented is what I found (after ALLOT of "trial & error", part swaps, you name it) worked for my car/setup. "Your mileage may vary".. With all the guess work done, the install so go very quickly. BTW, if you do decide to do the project, at time of service activation, call Sirius and tell them you just bought the system through Porsche and wish to activate your three month FREE subscription service!:thumbup: Enjoy! |
I have a question about adding the new Gateway 500 with the OEM sat radio module in my 07 997 TT with PCM and No c/d changer.
It is not clear where to add what components in the MOST circle. Here is the link to the Denison instruction manual - http://http://www.dension.com/sites/...tall_guide.pdf Any advice would be welcome ! |
David, great write up(very detailed) and in PDF format even... thanks for sharing with everyone. I'll add your posting to my DIY Index Post. BTW, the file downloaded in 2 secs from Firefox.
Originally Posted by lic265
(Post 9717368)
It is not clear where to add what components in the MOST circle. Here is the link to the Denison instruction manual - http://http://www.dension.com/sites/...tall_guide.pdf Any advice would be welcome ! 1) PCM 2) Tooki BT (This was later, added AFTER Denison my initial install, so you should be ok without it) 3) Denison/CDC 4) OEM Sirius Sat. Radio 5) Nav 6) Bose AMP As I had already a CDC, programing via PWIS was not required in my case. Hope this helps. |
If RapidShare link no longer works doe Doc download then try downloading from my Dropbox account:
https://dl.dropbox.com/u/82906075/DI...io_Install.pdf |
Originally Posted by Musclehedz101
(Post 10114647)
Hey guys doesn't this Audi OEM Sirius receiver look identical to the Cayenne receiver ?
Both made by Delphi. Wonder if compatible? Here is the link from Ebay: http://www.ebay.com/itm/Sirius-XM-Ra...f90fae&vxp=mtr |
Originally Posted by vladeden
(Post 10117311)
Dropbox Link (Tested and verfiied) for PDF on DIY "How To"...
Worked for me - thanks! Great write-up!
Does anyone have a working link to this guide? Thanks!
