Short Shifter
A couple of questions about the Short Shift Kit which I'm thinking of ordering for my 997.2 C2S.
1. Does it include a new gear lever or does it use the existing lever linked to new oily parts beneath the leather housing?
2. Is it worth it for "spirited" road use alone (maybe on one track day a year)? I started the current thread on "heel and toe" and anyone reading that will understand I'm aiming for the the perfect shift!!
Thanks for any advice
In a recent Excellence article comparing two 700hp Turbos on the road and track using professional drivers for their opinions, if I'm not mistaken, I remember a comment on the SSK. For track use, they didn't like it because it was easier to miss shifts. Seems to me there are performance driven mods that would enhance the car on the track and there are street mods...sometimes being good at one doesn't make it good at the other, perhaps?
J
J
I have the short shift and its lovely very precise and positive just what you want in your porsche!
I've driven the normal shift and its fine but the short shift just adds to the overall experience....I've never missed a shift with it either..(and I have zero talent)
I would highly recommend it, 2nd to 3rd is like a rifle bolt action (you'll be used to that in the US!)
There is something to consider about utilizing the short shift kit in the 997 street car. The synchronizers in the gearbox of this car, while fairly well thought out, have a material that has been prone to wearing quite quickly. Replacement parts while also now available, are quite expensive and only available as a set, (just over $600.00 per gear in 3rd and 4th) Here is why I bring this up.
By bringing a short shifter kit into the equation, you are essentially asking the synchronizers to work a bit harder to engage the gears, this is particularly true in quick aggressive shifting. While I believe that the feel is a bit crisper, the cost of this modification in the long run may out weigh the short term benefits.
Just my .02 cents on this, and something that I thought that you might want to consider.
Erik Johnson
GBox Performance Transaxle
(303) 440-8899 work
(303) 895-4828 cell
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
Moderator
I never thought I'd want or like a SSK. Had the regular on my 07 C2S but my 997 GT3 shifter was so much nicer. So when Porsche Huntington was selling the OEM SSK for $299 with free ground shipping, I picked one up. Extremely happy I did so on both street and track. Feels like my GT3 shifter, but without as much spring tension on the gate return-to-neutral. Would certainly do it again. It's Porsche OEM installed by Porsche dealer, so I'm not worried about compatibility, possible future warranty issues, etc.
J
J
and overall, do you recommend it? I am in the same boat as OP and a bit on the fence whether or not it's worth it.
Thnx
Moderator
The shifter on the GT3 was brilliant from the factory, so I never touched it. The 997.2 C2S shifter worked fine, but was "long and sloppy" compared to the precision of the GT3. So I took a chance and tried the 997 OEM SSK on my 2009 C2S and find it to be again, brilliant, like mine was in my GT3. In the before / after comparison I am surprised this isn't the standard shifter for the C2S.
I love my OEM SSK. The feel and the click when the lever slips into gear is simply fantastic. I don't track, so can't comment on its use there. I've never missed a shift even in spirited street driving, and I also have zero talent.
I also love my OEM SSK.
I wasn't specifically looking for one with the SSK, however, I found one
and once I drove it, I realized how crisp and performance oriented it
is verses the standard throw.
Keep in mind, when the engine is cold, the short shifter is a bit stiff
from 1st to 2d. Once it warms, it's silky smooth and very precise.
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
Chad
Do you know if manual shifter on 997.1 and 997.2 are the same? and hence the SSK similar on both?
Everything is new, lever and all and a world of a difference. It's at least half the throw distance from stock.
