PCM Single CD failure, dealer says replace entire unit...
McCulla,
Is there a fuse for the PCM? maybe worth pulling out for a minute and replacing to "reset"
Leave it out waiting for the fix to prevent battery discharge maybe
Now, if we get FLAC at 24-bit, then that's a different story, and true obsoletion of CD!
my 06'S has done this before as well. I thought I spaced and forgot to put the cd in, so I went to put another disc in and it forced the initial cd to load. It was a burned cd so I figured I had a thin disc or something.
Heck, I have hundreds and hundreds of CDs.
I ain't spending hundreds of hours converting them to another format. I don't fly on the space shuttle where I can only bring 19 ounces of personal property around with me.
Personally, I'm tired of getting sucked into the latest technology because all it does is make you do something you don't need to do. I got rid of my iPhone, I finally thought "This is BS," I had to put a stop to it!
Absolutely no disrespect aimed at the guys who keep up with the latest gizmos: more power to them!
Another clue I just remembered. The CD drive will hummmm and buzzzzz a little bit until it tires itself out. Then it will stop. Turn the car on and then shut it off and the PCM starts humming and buzzing all over again until it decides to stop. If that happens to yours it's ONE sure clue the thing is toast.
Though I am of the Ipod generation, I have ~ one thousand CDs. I still only buy music on CD and I rip it for my Ipod. Fact is, MP3s sound vastly inferior to CDs. You might not be able to tell in a loud Porsche, but you sure can on any good stereo. I can even tell in the Porsche. If you must listen to MP3s, the 06 and later PCM plays MP3 CDs, which always seemed a better option to me than a complicated Ipod install.
At any rate, I assume OP has already tried this, but I once got a DVD-A accidentally stuck in my PCM. I repeatedly turned the ignition on and off, and tried the eject button. It took a dozen or more times, but it eventually coughed it up.
Received 2,683 Likes
An old Volvo V70 we had used to do that as well. The first time it happened, on a long 2000km road trip heading to a 2 week holiday in Queensland, we called Volvo and got told the only option was to swap out the whole unit for a reconditioned one at some daft price.
With nothing to loose, when we got there I bought a $2 pack of screwdrivers, took the thing out, pulled it apart and fixed it. Took about 2 hours total. My daughter even thought it was fun to pull the car apart together so we ended up having some fun at the same time. Life can be strange sometimes!
As someone else says, sounds like you're in the same boat if your alternative is $1700.
Llbr, I have noticed the ongoing attempts to eject a CD that is not actually in the player, when the car is shut off. I sat in the car tonight to just listen for about 10 minutes and it only went through this dance until the car "shut down". I was cleaning the inside yesterday and heard the multiple attempts to eject but hadn't actually put a disc in until today. I'll be interested to see what Mother Porsche has to say in a few days.
I didn't mean to threadjack, but this has just been a great solution for me in the car, and I thought I would share.
Poseur
McC--best of luck with the resolution of this. Sadly, the 05 model year PCMs have a higher failure incidence than the later ones. That should be used against Porsche in that they have a known shortcoming. Perhaps they will go to bat for you. And that crap about your extended warranty company weaseling out! Make sure we ALL know here on Rennlist who that company is so that we can give them 'the business,' if you know what I mean...
If you using an iPod, WAV or Apple Lossless are you best bets. However, MP3 at 320k is for most people, impossible to distinguish from CD audio. That said, storage is a plenty these days and I don't see much point in MP3 no matter how it sounds. - other than that is is ubiquitous and not part of an annoying Microsoft/Apple turf war.
We've ripped all our CDs to WAV as well. Discs are just too clumsy to deal with on a daily basis compared to hard drives - especially in the car.
Actually, you can rip the CDs to full quality WAV (44.1/16-bit), Apple Lossless or Lossless WMA. FLAC at 24-bit would add nothing to any consumer music, since nothing is released at bit depths greater than 16 other than DTS, SACD, and DVDA which you cannot rip anyway.
http://blog.bowers-wilkins.com/lab/?p=262
Only FLAC, ALAC and WMV lossless are as good as CD. Mp3 has many flaws which is definitely measurable... see here:
http://www.stereophile.com/features/308mp3cd/
The same exact thing happened to my '06 Cab S, luckily it was still under warranty. I was unable to eject the CD from the single player. The service manager said that the whole PCM unit had to be replaced and that it was not a simple jam. I hope you are able to get your issue resolved without a major dent to your wallet.
Here's a suggestion. This same issue happened to me on my 05. I took another CD and pushed it into the slot. I caught the edge of the CD that was stuck and just gave it a little nudge further in. Sure enough, it moved and then ejected. Never had a problem since then.
