Spare Key (Valet Key) photo?
#31
#32
#35
curious on price.. hopefully under 100..
#36
[QUOTE=rijowysock;7291883
curious on price.. hopefully under 100..[/QUOTE]
Yeah right. AFAIK, Porsche costs at the dealer service are in $100 increments only. It'll be $100 if we're lucky. $200 if it's a normal day.
#37
i get mine tomorrow.. ill let you know.. dealer said its only under 06 in the system but he can order for 06 and give new vin so gets cut to the new car.. and just gotta wake it up by putting in ignition or something.
#39
The passive memory chip that holds the code for the ignition authorisation, transponder, is molded into the key head. The ECU will normally program it as a clone provided the other master keys are available and have to be inserted first in the ignition. May need the exact procedure for Porsche.
#40
cool - can't wait to hear how it goes. pls post the part no. also.
#42
#44
anyone ever figure out this procedure.. on my 997.1/997.2 i never got the "spare" programmed because they wanted 200$.. but curious now because i loved the key for the beach/sports.... generally just use to unlock door w/ real fob inside but would be nice to have it work should i need it.
#45
Good point. But do you even need it programmed at all? If its just cut to be able to mechanically open the door, and you keep the full key hidden but in easy access inside the door, could you then use the cut spare to open the door, retrieve the hidden real key inside, and be able to shut off the alarm before it makes too much of a racket? (or would it, given you locked the door with the spare key, never arm the alarm?)
i've done the plastic twice, but always wish it worked for "just incase"
