Ethanol-free gas?
The investment we have in our vehicles is at the peril of these looney policies and, we the people, must tell them that we are not going to take it any longer.
PAG is OK with 10% ethanol, but I think it is at the edge. The stuff is corrosive and hygroscopic and can cause havoc with injectors with water and crap created by alcohol reactions deposited at the bottom of the tank. 15% is unacceptable.
Super Moderator
Needs More Cowbell
Needs More Cowbell
It is also a spec fuel for Rotax kart engines and is fairly common to be available for local kart tracks.
Zero ethanol, unleaded, perfect (motor) octane rating.
VP Fuels ??
I read most gas stations are not certified to run 15% ethanol gas. The 15 is average percentage, which means ethanol level can fluctuate +/- 2-3 percentages; and this is where the issue lies: today's cars are not designed to run 18-20% ethanol nor are gas stations certified to run them.
Unless Ethanol consortium decides to fund all gas stations modification to be 15% certified, I think think it will happen.
I heard Ethanol is bad for direct pistion injection cars... I put "no ethanol" gas in my wife's SLK280.
I presume you meant '[E15] will not happen'.
Where do you readily find ethanol-free gas?
When I do DE's at Sebring they sell Sunoco 93 NO ETHANOL and to be honest I can't tell any difference between this fuel and the Sunoco 93 I fill up with before I leave home tha has up to 10% Ethanol.
Also if you really have to have no Ethanol check with your local marina and see if they are still selling non ethanol fuel....most still do and see if they will let you fill up there. My opinion is it is not worth the hassle.
We can write our congressman and other government officals about this but they will not and do not care nor listen.
The issue to me is engine/fuel system longevity. Ethanol is highly corrosive and it is hygroscopic. All manufacturers, including PAG, advise against running empty (below the bottom 1/4 tank) when using E10, given the likelihood of the presence of water and corrosive debris caused by ethanol at the bottom of the tank. That is the issue.
it's one big scam, the farm lobby.
i hitched a ride at the 12 hrs of sebring a couple years ago with some junior lobbyist from the E85 coalition. i asked a simple question about the energy balance of ethanol and he went nuts on me. i really thought he was going to stop the golf cart.
as a recovering engineer pretty familiar with how to calculate the energy balance, i'm not sure my professors would have brought "war" and "human life" into the assumptions.
As far as availability of ethanal free gas in CA., as Mark stated, VP Fuels sells several unleaded eth free fuels. C-10 and MS93 both meet that spec. R+M/2 oct. rating of 100 and 94.5 respectively. Cost is approx. $6.00 gal.
Here's the catch with those fuels. They are not CARB(CA air resources board)-legal fuels for road use. The ethanol is an oxygenator that helps fuel burn cleaner at cold temps.. I've seen you scold others for removing the cats from their cars, well this is a simular issue. If you want to be PC, run the ethanol.
On a side note, just yesterday I topped my car off with VP100. This is an oxygenated with ethanol, CARB legal, 100 octane fuel, that is sold at the pump throughout CA. Still has the ethanol in it, but is legal to burn on the highway, and has super high octane rating. VP actually recommends mixing it with premium gas in areas that only have 91 octane available at the pumps, (like CA) for cars that call for higher octane (Porsche). Cost was $6.06 per gal.
Maybe a solution to your dilemma of one day being faced with only E15 at the pump would be to blend in some VP, C-10 with the E-15 and lower the ethanol and raise the octane for a more compatible fuel for the 911.
Hope this helps.
Wishing us good luck for the future!
Phil
... Here's the catch with those fuels. They are not CARB(CA air resources board)-legal fuels for road use. The ethanol is an oxygenator that helps fuel burn cleaner at cold temps.. I've seen you scold others for removing the cats from their cars, well this is a simular issue. If you want to be PC, run the ethanol.
Gotta wonder if it is not the ethanol that is getting it to 100 Octane?
http://en.wikipedia.org/wiki/Octane_rating
