OEM Sunshade?
#32
I have the exact same one as shown, 996 part.
PHDX2 do you have a secret as to how you keep the shade from extending so far down on the dsah as to miss the sun visors when down? It works OK, but I'd say it aint perfect for that reason.
#35
How firmly are you pressing the sunshield into place at the base of the windshield? I don't note any flexibility in the gap between the dashboard and windshield, but perhaps if sufficient pressure was applied at some earlier point (or perhaps due to an issue with production), the molding might be out of place, causing the sunshield to slide too deeply into this gap.
At the moment, no other ideas come to mind. Just as communicated in my prior posts, the sunshield fits perfectly in my 997.
Hope you are able to resolve this matter. Nice car, by the way!
#36
Fitting
Hi Guys, i just got a solar shield from autogeek.net. while it seems to fit ok, i am not sure. it has about 1 inch of glass showing on each side. is this correct, or do i need to go to a official porsche product. It was ordered specifically for the 06 997, but i dont think it should be glass on either side? Help !
#37
#38
not sure
will check the packing slip in the office tommorow, but it is from cover craft and i called them and they said it was normal, but it just does not seem correct if it is a custom fitted part
#39
As illustrated in the photos presented in my earlier post, the OEM sunshield provides full coverage. Only slight light seepage is present around the corners and, of course, at the cutout for the mirror.
#40
The 996 OEM part was made by CoverCraft and the only diff to the product they sell direct is the labeling.
#41
Cover Craft
Yes, the number is what you say it should be, however does anyone on this board actually have the unit on a 997 ? Mine is narrow on either side by 1.5 inches. I just dont feel it is really custom for the car. Up and down it is fine, even the opening where the mirror is works for me. To me it is not designed for a 997 . comments ?
#42
P.S. - looking at post #30, it looks like that PHDX2's OEM cover also has a gap horizontally (we know it has a significant one vertically).
#43
Crazy
You know what is crazy is that for 4 years, no sun shade, now that i have one, i want it to block out all the rays. I can say the car is significantly cooler with it on and will protect the dash from the florida sun. I am calling champion tommorow and see if they have the OEM, if they do, i will drive over and try it.
If it fits better than the covercraft i will advise.
#44
For a total fit and coverage, I guess nothing beats the HeatShield from CanvasWorks but it does not look as sharp as the one you have now.
#45
Out of Stock
Champion currently out of stock but will have them next week around wednesday or Thursday. I will go there and put the unit against the cover craft so that this string will come to a an end with the results
