OEM Sunshade?
UPDATE
UPDATE: the Part No. PNA-505-996 is indeed a 996 part number. I verified this calling Carlsen. They claim the 997 fit is good - the question is how good? Does anyone know?
I contacted Covercraft who was making the 996 shade for Porsche and they have a fitted unit for the 997 (CoverCraft PN UV11029).
I ordered one from AutoAnything. This one will fit. It also has the advantage of not having the Porsche badge with the added bonus of being more discrete.
discreet
Is that because you could not tell its a porsche without the word porsche on the sunshade?
I just ordered a blank one from autogeek.net
cannot wait to get it
Just thought I’d add that the referenced OEM sunshield (PNA-505-996) indeed fits the 997. I use this particular sunshield, purchased from Carlsen Porsche, and have nothing but good things to say regarding the product. It provides full coverage with a perfect fit and is easy to install and remove.
Got one from Performance Products and it fit my 2007 Turbo perfectly. Cost was $40. Made of the soft material that you roll up. Silver on outside and white material on inside of shield. Has velcro strap to hold it together when rolled up and not in use
since you asked about fit, I have the 997 model and find it's a little too short - it works fine, but if you push it all the way down the dash it doesn't quite reach the sun visors when down for anchoring. YMMV
I assume you say that your car is a 997 and you are using the OEM 996 shade which is a bit short.
Note that the 997’s sun visors do not extend to the point that they push the sunshield flat against the windshield. Instead, the sunshield rests on the sun visors an inch or two away from the windshield.
Hope this helps…
