Serpentine Belt Failure
#32
Newbies Hospitality Director
Dan, thanks for the update. This is very interesting topic.
When they replaced your the water pump at 9K mikes, maybe the tech set too much tension on the tensioning pulley, thus causing the recent issue. The water pump failure "could" have been an isolated incident, not related to too much tension on the pulley, or the water pump failure "could" have been a result of too much tension on the pulley. Obviously, relative to the water pump failure, it is impossible to determine which was the cause and which was the symptom.
#33
My belt has squealed from the first day. It only does it from a stop, and only instantaneously when I accelerate. I've had it looked at twice, and they replaced the belt once. After reading this thread I'm wondering if there isn't something else going on that I need to have addressed. Very interesting,
Thanks for the post Dan….
#34
As Dan commented earlier, we ran into another club member at the dealership who had his car in for the sway bar linkage issue. (My front sway bar links will be replaced tomorrow).We then checked his pulleys and noticed he had some grooves developing on them.
#35
In my case, I have a squeak that is heard on each cycle of the serpentine belt. It occurs approximately at a frequency of 2Hz, or 2 cycles per second, at idle.
#36
Poseur
I asked the mechanic about the tensioner and whether there is some ideal setting for them. He indicated that the tension is fixed. It is governed by a spring within an arm that is attached to the tensioner pulley. (Not hydraulic nor adjustable).
The 997.2 engines appear to have a fully separate tensioner which may provide Porsche with a range of tension settings, but this is purely speculation on my part right now.
As always, I will continue to research this. I recommend for even the armchair mechanics to go out to your engines and feel for grooves on that top idler pulley. You may discover something.
#38
Poseur
The real question is the troubleshooting cost.
They also have completely flushed the coolant system (5 gallons at $23 a gallon) and replaced all of it, along with a new coolant cap ($15).
#39
Those pulleys are not made out of just mere plastic; they look more like composite material. And being made of composites I'm sure they're not cheap. They're likely more expensive than had they been made of aluminum alloy material.
#40
Poseur
If there's a Porsche Part Nr. on it it will be expensive. I will try to get the run down on the prices on Thursday when I pick up the car.
(At least I'm also getting two new PSE sport mufflers and two new exhaust thingys (the shiny things) too, tomorrow!)--Separate issue. (Fractured welds on these things' mounting points).
#43
Hello Edgy
Sounds just like airplane parts. The GE light bulb at Sears costs 29cts. The same FAA approved bulb w the matching part numbers +1 suddenly is $4.89. And where is the difference ? Put them all in the same bag and you could never tell.
Sorry to hear about your belt issues, hope that your excellent reporting on this event will help us all around to better grasp what is going on behind our backs.
Thank you, and have a great summer drive this year
#44
Also take a look at the tensioner which can sometimes be the culprit. Another brand I used to own would at first misalign the belt and then start cutting parts off until the belt was gone.
#45
