Spark Plug interval
Spark Plug interval
What's the spark plug interval on '05 911 (base)?
I thought that it was 40 K miles. That's what one dealer said but when I called another one he said it is 60 K. I recall seeing 40 K somewhere in the Porsche literature but he said that applies only to turbos.
(Of course when I talk about 40K I mean the milage not the cost of the service )
Yikes I'm coming up on 4 years in a couple of months. I had been planning on 60K miles. Didn't realize there was a 4 year spec for replacement.
I don't know that I really buy into the 4 year requirement. Spark plugs don't wear out based on time. They wear out based on usage/mileage. Just like brake pads and clutch disks.
Might be a corrosion issue... letting plugs remain too long...
On a related note, if you plan on keeping car a long time you might consider having the exhaust manifold gaskets at the exhaust manifold/head interface replaced. Even if gaskets do not need it and they probably don't, this gets the exhaust bolts removed and replaced with new bolts, new thread lube and of course new gaskets.
Then later when car out of warranty and you might be faced with some exhaust work -- like replace a converter (like I'm facing with my car) -- you have a better chance of getting the exhaust bolts out without damaging the threaded holes in the heads. These holes can be fitted with thread inserts but easier to have mech. do it while car on lift at shop with all the tools vs maybe doing it in your driveway or garage.
Sincerely,
Macster.
I did a search and most people who are handy can replace them in..
1-2 hours. I can't imagine an experience mechanic taking more than an hour.
Then, again Porsche charges $700-800 for the two year service that requires an oil/filter, air filter, and making sure that all the other fluids are okay.
Gentlemen, its time you talk to your father and start getting your little hands dirty...unless you really don't care about how things work and don't mind dishing out big money.
abe
abe
