Softronic ECU Flash - Waking Up Your 997
Old 06-18-2008, 11:01 PM
  #46
Deanski
Deanski's Avatar
Sounds damn fare to me. What's to loose?
With other companies charging big $$ with no real way to refund software.
I'd love to try one, but now, I'm in search of Bridgestone RE050A's which are harder to find than Osama.
Those looking to even try flashing the ECU, I'd go for it!
Deanski
Old 06-18-2008, 11:52 PM
  #47
mdrums
mdrums's Avatar
Originally Posted by vividracing
Dyno numbers can be fudged, and alot depends on the before and after condition, mods on the car, tiptronic or 6speed, etc. What I have done with other customers is flash the car, if you think the product is not worth it, flash it back to stock and return the cable within 10 days of doing it for a full refund.
I am considering a dyno run on my 997S with the Softronic flash in it. My car is stock except for Fabspeed mufflers and the Softronic flash. My car is a Tiptronic so I fugre that transmission eats up some HP/TQ. Have you dyno'd a car like mine and if so what were the numbers?
thanks!
Old 06-19-2008, 01:36 AM
  #48
Vitamin_J
Vitamin_J's Avatar
bump for mdrums. Enquiring minds remain curious.
Old 06-19-2008, 01:58 AM
  #49
evolvedaz
Former Vendor
evolvedaz's Avatar
i should hopefully have a 997S in the shop soon to get before and after dyno runs.
Old 06-19-2008, 11:32 PM
  #50
DJ23
DJ23's Avatar
Dan, How does your Softronic compare to the Revo upgrade? I have the Revo chip and have achieved a great lift in performance. It would be interesting to compare the two on a Dyno of the same car and specs.
Jay
Old 06-20-2008, 12:06 PM
  #51
evolvedaz
Former Vendor
evolvedaz's Avatar
Great question. Here is how Softronic compares as a whole to EVERY flash company out there.
First Softronic is the only OBDII software that cannot be detected by the factory Porsche scan tool. If Porsche were to hook up to the car, they would not see any instance of the data being altered. 2nd, Softronic gives you the best map the first time. They tune off the factory knock and oxygen sensors. So there is no need to have a "Race" file or reflash for basic mods such as exhaust, intake, different octane gas. The ECU will adjust accordingly. 3rd, Softronic physically goes in and changes each individual table as necessary. Other companies do a "Global" change where they will do a +1 or -2 for example to change the variables across the entire field. This works, but is sloppy. 4th, if you were unaware, your car ships with the "valet" mode from Porsche directly, this is something you can change in your onboard computer, this is not an added advantage with a flash.
Old 06-20-2008, 08:09 PM
  #52
DJ23
DJ23's Avatar
Thanks for the note Dan. I didn't know that the ECU reprogrammed on its own with the addition of modifications. Sounds like a great enhancement that performs with such spontaneity.
Jay
Old 06-20-2008, 08:14 PM
  #53
CBejbl
CBejbl's Avatar
Please tell me more about this valet setting and how to change it.......thanks.
  #54
evolvedaz
Former Vendor
evolvedaz's Avatar
We will be doing a before and after on a 997C4S on wednesday. We will try to have video, pictures, and info posted then.
Old 07-12-2008, 02:00 AM
  #55
Vjgtrybno1
Vjgtrybno1's Avatar
bump for dyno results...
Old 07-12-2008, 12:03 PM
  #56
evolvedaz
Former Vendor
evolvedaz's Avatar
I apologize, we will have one.
Old 01-09-2015, 02:30 PM
  #57
997_Toronto
997_Toronto's Avatar
As soon as I saw this post I remembered reading Walter's post. Am I wrong in assuming that things could vary on a car by car basis? A lot of very happy Softronic customers out there and a few not so happy.
Walter...how long after the flash did your issues start to occur?
On a side note...would also love to see some dyno results.
Last edited by Bob Rouleau; 01-09-2015 at 09:24 PM. Reason: deleted material from deleted post
Old 01-09-2015, 07:37 PM
  #58
TheLex
TheLex's Avatar
Apparently "Walter" was not the original owner of the car. He purchased the vehicle with the software already modified. When he had a problem he did not work with Softronic to resolve the problem.
Also he apparently posted this same information/complaint under different handles on 6speedonline where he has been banned.
In fact his linked thread has been terminated.
Quick Reply: Softronic ECU Flash - Waking Up Your 997
